SOURCE: Pfaff 7570 creative card
Hi Eva,
You should be able to clear the card by holding down the card key as you turn on the machine. You should then be able to reformat.
Linnette
SOURCE: Have 3D software,Pfaff 2140 machine and Hus Designer Diamond mach
I have loaded the 4D software and have communication with my Husquvarna machine through that. I communicate with my Pfaff through the old 3D software on my computer.
SOURCE: connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
SOURCE: Pfaff Creative Vision embroidery/sewing machine says motor overload then shuts down
I had the same problem and it was my power supply. I've had more than my share of problems with this machine and it's only 3.5 years old. Good luck.
SOURCE: where to buy another creative blank pfaff 7570 card
I purchased a new Pfaff embroidery machine in 4/2000. A creative blank card came with the machine.The card worked fine. I purchased another blank card- Centennial PCMCIA SRAM Recharge card (bought on internet-site ? can not remember) to use when I started another project before I finished what was on the Pfaff creative card. About 2 years ago the cards( Pfaff & Centennial) couldn't hold a design over night.I tried to recharge the cards-not successful.. Now in April of this year the cards couldn't accept a design at all. In trying to transfer a design from my computer to the embroidery machine-a symbol appeared-- Computer-line connecting with- the sewing machine but no design transferred. A friend's husband suggested Allbrands.com. I bought a new creative card ($69.00) & am waiting for it to arrive. The cards that you buy with designs already on them -the machine can read and I can sew them out. No luck though with the blank cards. Denise
