There you go:
Thanks
Ok I guess need more help locating the fuses.
Or help in diagnosing issue
I guess I need more locating fuses on the cart
look for inline fuse at the converter
it might also be a wiring issue
SOURCE: Citroen C15 Diesel Van.
It definitely sounds like the electrical part of your ignition isn't working properly.When you turn the key, the lck and tumbler turns on the ign. switch in which sends power to the rest of the car.
SOURCE: wiring diagram or fuse box diagram-2007 GMC Envoy Denali
Hi there;
Here is the wiring diagram for the trailer wiring for your truck.
Hope this helps
Farrout!
SOURCE: 2000 Mazda 626 brake lights
It may be the switch on the brake pedal, it should be located on top of the brake pedal arn.
SOURCE: plugged in a trailer and now brake lights and horn don't work
There definitely should be a fuse for your brake lights. It should be inside the car fuse box, but sometimes it'll be under the hood (very rare). There's also a switch above the brake pedal that turns your brake lights on. This switch may be faulty
SOURCE: horn does not work. relay and fuse good, need wiring diagram
Had the same problem myself i just replaced the horn itself.
