SOURCE: Repair manual for a KitchenAid K45SS stand mixer
You should be able to look up your manuals HERE
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the
wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways
round, there is a key on one corner which means it will only go in one
direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
SOURCE: Kitchenaid Ultra Power Stand mixer manual or
Hi RFRICK753, There are no specific instructions to 'oil' your KA mixer. Your KA mixer's internal gears are factory packed with enough grease to last, with normal use, pretty much a lifetime. As grease will, over time, tend to break down, you may find the oil component of it seeping from openings beyond the gasket and "O"-ring down the agitator shaft. Gravity can be very insidious. But generally speaking if your mixer appears to be operating normally as it has in the past, you should not be overly concerned about 'oiling' it. If, however, you feel it necessary to perform some TLC on your mixer, the good news is that the inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals& Guides> then enter the visitor type "Consumer" and enter the 6 character model number, in this case KSM90P, and select any file under Parts List (16); say KSM90PSAC0.pdf (354.08 KB) for example (all 16 manuals are exactly the same, but it's still wise to check and see if it matches your mixer, though). Although not providing step by step instructions, the Parts List manual provides an exploded view of the various component assemblies allowing you to see how the mixer all fits together. It is helpful for the disassembly, troubleshooting, and reassembly of your mixer. You'll find it quite messy 'under the hood' in the transmission box, but you'll be able to ascertain whether you really need to re-grease or not. Also, while your mixer's apart is an opportunity to check for any other unseemly wear and tear on the gears, etc. After getting your hands this dirty, you may want to order a transmission gasket, an "O"-ring, along with some food-grade grease. Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping. Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same. Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to peek under the hood and assess any maintenance needs for your mixer.
SOURCE: kitchenaid stand mixer attachment stuck
This has happened to me - however, the attachment pushed up and down on the spring with no trouble, and also turned.
The problem, it turned out, was the metal pin that sticks out - was sticking out TOO FAR. I put some WD-40 on the outside of the pin, and I used a small screwdriver and a hammer and gave it a few whacks so the pin moved back a bit. Once I did that, I could push up the attachment and unscrew it as normal.
When it's off, look at the pin and make sure it sticks out at least flush on one side if not protruding a little.
SOURCE: Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
