Here's the link and I'm sure you will get the solution of your problem
Ford Laser sedan 1998 Wiring Diagram Repair Service Manual
SOURCE: How do i remove door trim on a 1998 ford laser lxi
there will be a few screws in the panel espically around the door handle. After that you will have to carefully pry under the door panel to release the clips that hold the panel on. I always start in the lower corner and work my way around. once you have the panel loose, you will have to lift the panel up off the door because of the window trim.
SOURCE: Stereo Wiring 1984 VW Rabbit
red brown is speaker(rear left),grey blue is remote for anntena.Hmm,red black possible is a amp or a live one(+12V)
SOURCE: wiring diagram to fit stereo in 1998 ford escort
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
SOURCE: security coded car radio for a Ford Laser
You would have to remove the radio and this label will be on the right hand side...
There are different codes for different radios. I'm sorry, I can't think of an easier way aside from taking it to the dealer or going to...
www.fordradiocode.com and paying $9.99 and they still need the serial number.
Testimonial: "Thankyou so much, I now no exactly how to fix the problem.. cheers"
