SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you
have one the "magic" button for three seconds, a light should then
flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at [email protected].
SOURCE: Emerson Jumbo Remote Code for Motorola Cable Box Needed!!!
I just used 051 with the giant emerson remote and a motorola cable box. It worked right away. Good luck.
SOURCE: Unicersal Remote code for Motorola cable box
I found this on another site: It works BUT you don't have all the functionality you would have with the cable remote (of course). If you want power on/off, vol up/down and channel change.. this is your fix.
Was this comment useful?
new Starbox("rating1496612", 0.0, {identity: 1496612, stars: 5, buttons: 5, max: 5, total: 0, onRate: saveVote});
I got mine to work using the Code search method. The manual is incorrect though about using the code search: Instead of pressing Power repeatedly, you just press it once. It sequences through the codes. You then need to press Enter immediately when the comcast unit turns off.
