The recorder should be connected to the mixer but any mismatch of the impedance or recorder input sensitivity/mixer output level can cause anything from a small lack of quality to serious overload resulting in great distortion.
A mixer could realistically have a peak output of a couple of volts and the power amplifier could need that amount to produce full volume but your recorder could need only a few millivolts if it can record from a moving coil microphone or magnetic phono cartridge.
It could be desirable to use a an additional preamp or even a simple attenuator to reduce the output of the mixer to a level suitable for the recorder input.
If the mixer has an output for monitoring it would be ideal for connecting a recorder but I strongly suggest you are guided by the instruction manuals of both units.
U connect the recorder to the audio outputs of mixer. If you only have one set of outputs, get a y adapter and have one set of outputs go to the recorder and other set to the amp.
SOURCE: recording
Connect the analogue inouts of the recorder to the monitor or tape outputs on the mixer.
