20 Most Recent
Philips CDR765 2-Disc CD Recorder Questions & Answers
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit. The manual is available from Philips here:
www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF). I hope this helps. Cindy Wells
I have a CDR 765
hola
la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
It wont record all my cd tracks, its starts
Sounds more like it won't record ANY of your CD tracks. Is there any indication why? Are you sure it has audio coming in? Many CD recorders will automatically stop recording if they sense extended silence.
NECESITO EL PLANO O DIAGRAMA
la solucion a el manual de esta grabadora esta en retrevo.com/manuals.. ellos tienen infinidad de manuales para toda clase de aparatos electronicos incluyendo grabadoras de cdr..espero tengas suerte en encontrar el manual..suerte
I can't get it to record
Are you using a blank media or a CD, if you put a DVD in it won't record on that. Read the manual that came with the unit.
How do you record
You put blank media in the record side and hit the record button. These CD recorders are not as easy as using a Cassette deck. You need to Finalize the disc before it can be read on a standard CD player.
No power
Check the power cord first. If it is OK, check the fuse inside the device. There is glass cargtridge type, repalcable fuse, can be located on the main power supply regualtor board.
