20 Most Recent Sony RCD-W500C 5-Disc CD Recorder Questions & Answers
How do you change the belts on deck B?
12/13/2022 8:02:49 PM • Sony RCD-W500C... • Answered on Dec 13, 2022
My door will not open
Do either doors open or is it just one? If just one, which one WILL NOT OPEN?
11/23/2022 3:03:10 AM • Sony RCD-W500C... • Answered on Nov 23, 2022
2answers
For sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
4/11/2021 10:51:11 PM • Sony RCD-W500C... • Answered on Apr 11, 2021
HOW DO i GET BELTS FOR THIS CHANGER
If you have the old belts, take them to Ace hardware and look for o-rings that are the same size. They work well for replacement belts.
7/27/2020 1:21:02 AM • Sony RCD-W500C... • Answered on Jul 27, 2020
After recording, I recieve a toc error c14 when I try to finalize it. How can I fix this problem?
There's a solution to the problem : the problem is one word..; '''Sony''. Throw the unit away as to my knowledge there is no company who makes discs that will allow a TOC (table of contents) to be written to the disc. All those Sony units were only designed to be accept Maxell CD-R Music Pro blank discs. They are unfortunately unavailable /no longer being produced. Step one: .Buy a Tascam recorder they accept consumer grade cds.. Step two: Boycott Sony as most of us who owned one of their standalone units didn't get two years of use out of it..including myself and most i've ever talked to about it.
9/28/2017 5:07:28 AM • Sony RCD-W500C... • Answered on Sep 28, 2017
Recorder will not read blanks or play disc
The device has failed, it happens all to often, this is the exact symptom, problem? the laser light is most likely burned out.
1/19/2017 11:05:46 PM • Sony RCD-W500C... • Answered on Jan 19, 2017
Order a part for my tdk da 3826 2 disc cd recorder
What do you need?
1/6/2017 2:32:25 AM • Sony RCD-W500C... • Answered on Jan 06, 2017
I havee been trying to
Manuals are always a good place to start.
You ARE using a data disc. It's literal. RTM and see that it only uses blank media that say "Digital Audio" on them.
Web search "Sony RCD-W500C manual"
3/31/2016 9:13:03 PM • Sony RCD-W500C... • Answered on Mar 31, 2016
2answers
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
3/31/2016 9:07:18 PM • Sony RCD-W500C... • Answered on Mar 31, 2016
Using a sony cdr audio disc during recording it
The manual suggest vibration may have interfered with the recording for the C13 error.
Check your email for the manual.
2/28/2016 3:38:24 AM • Sony RCD-W500C... • Answered on Feb 28, 2016
On model sony rcdw500c how dose the A deck door open or eject
They are quite a few belts which drive deck a in this model. Make sure a cd isn't jammed.
8/25/2015 9:01:52 PM • Sony RCD-W500C... • Answered on Aug 25, 2015
The Cds get stuck in the unit; unit won't play and cd drawer won't open
HAVE YOU tried to open the tray by the pin hole on the front with a paper clip
7/7/2015 8:07:24 AM • Sony RCD-W500C... • Answered on Jul 07, 2015
The unit play through the recording deck but will not record
What CDs are you using? Audio ones? This may be what you are looking for: http://www.clasohlson.com/uk/CD-R-Audio/38-3216?LGWCODE=383216000;83827;4797&gclid=CNuDpMaL4cMCFcvJtAodTDgASA&gclsrc=aw.ds
2/14/2015 9:10:52 AM • Sony RCD-W500C... • Answered on Feb 14, 2015
How do I get the unit to record?
It doesn't require audio CDs, does it?
2/12/2015 10:12:02 PM • Sony RCD-W500C... • Answered on Feb 12, 2015
CD drawer continues to spin and doesn't stop at any disc, why?
I think there are opto sensors around the carousel, these may be faulty as the machine needs to know what position its at.
11/23/2014 1:04:56 PM • Sony RCD-W500C... • Answered on Nov 23, 2014
How do you connect Sony rcd-w500c to Sony tape deck to record tapes to CDs?
Line Out from the CD player/recorder goes to REC IN on the tape deck
9/12/2014 11:54:16 PM • Sony RCD-W500C... • Answered on Sep 12, 2014
Troubleshoot cd changer
Unfortunately, you have to remove the screws that hold the top cover on the player, unless you can remove the ones still in place one at a time through the door. If you can remove all the ones still in position, you might be able to get the remaining ones by flipping the player over.
8/22/2014 5:33:31 PM • Sony RCD-W500C... • Answered on Aug 22, 2014
Sony RCD-W500C 5-Disc CD Recorder Logo
183 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony rcd w500c w100 go record mode
  • Audio Players & Recorders
