Once I power cycle it comes on and works fine. But once I power off, it won't turn back on without power cycle. What can I test to determine what needs to be fixed. Not afraid to take back off and use a multimeter.
SOURCE: Turns on, cd light comes on but cpu does not boot
You should get it repaired. That is likely a power supply failure. Yes, I see you have power, but I still say power supply, because there are 2 types of power: There is Motherboard power and there is CPU power. If CPU power is not correctly flowing, the CPU will not activate. If the CPU is not active, the board will not process any information, even though the board is receiving power. Power supplies are not hard to replace and are usually about 40 bucks
SOURCE: my vizio vx37l will power up but it wont get any
My TV did the same thing. You need a new power supply. Fairly simple to do yourself. The card is about a hundred bucks with shipping. The part number is 0500-0507-0250. You just have to take the back of the TV off (about a hundred screws). Just unplug the old one and plug the new one in.
SOURCE: I have a 50" Vizio
It is the power supply that is going bad, you need to replace the power supply module and that will take care of your problem. You can also replace any electrolytic caps that are bad on the module itself, that would fix it too.
SOURCE: My acer aspire x3400 isn't working. When I press
first you need to disconnect your ram from mother board and turn on your computer
is there any beep sound?i long and 2 short?if yes it mean your ram was damaged, try connect another ram to your computer
and try to turn on your computer again
SOURCE: My dyson power button won't stay on unless you
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
