Music Logo
Ruairi O'Hare Posted on Jun 08, 2017
Hello i'm having issues with my guitar amp. Its a two channel electro acoustic amp and only one channel is working. Please help
5 Related Answers
Michial Gueffroy
  • 1140 Answers
  • Posted on Oct 28, 2009
SOURCE: hi have a pmp3000 what are the most suitable bass
Have you considered any of the Behringer cabinets that are recommended companion pieces for this mixer. For more expensive gear have a look at JBL cabinets. The EON series is good. Have a look at what other bands you know are using and listen to their sound to see if its what you like.
Fred Yearian
  • 5603 Answers
  • Posted on Dec 16, 2009
SOURCE: washburn acoustic electric guitar eq & turner
Try this site:
Select the lesson on "Tuning Machines"
This looks like a good resource for information.
Anonymous
  • 32 Answers
  • Posted on Jan 20, 2010
SOURCE: washburn acoustic guitar EQ & Tuner System
Here is a PDF Document on the system.
Washburn WT-92 Preamp
Anonymous
  • 11 Answers
  • Posted on Mar 10, 2011
SOURCE: I have a Fishman Classic
did you check if the D/A box is working?
xe77
Thomas P
  • 24 Answers
  • Posted on Apr 14, 2011
SOURCE: hi, i am having terrible
Check: monitor levels, microphone position, grounding. Is it possible the feedback is due to EMI noise off the power source?
2answers
Fishman LBX-001 2006 model. I'm having an issue with my guitar amp. It does not get any sound from an acoustic guitar, I tested my guitar in another amp and it works well. I plug an electric guitar into my...
I am no expert about such things but the electric guitar pickups work with steel strings, wouldn't work if the strings weren't steel - the pickup is a coil of wire and the vibration of the steel string generates an output in the coil the amplifier can work with.
The pickups of the acoustic guitar are presumably glorified microphones that would usually work in a similar fashion to the above, by generating an output but if they are active devices they will need a power supply in order to generate an output, something a standard amplifier input will not provide.
An active device either needs an independent power supply to make the device work like a radio needs a battery or the device will create the output by varying the current flow of the voltage applied across it.
Why won't play through amp and tuner not working
well my guess (from experience) is that, if the battery was inserted correctly and you know its good. and you know your cord is good and your volumes are up. then chances are the pick up ( which are very touchy in those) has gone bad and needs to be replaced. which if the guitar is fairly new. have them just switch out the guitar or send it in for the repair.
I have a Takamine acoustic eletric guitar model number eg560c serial numbers 2413693 how do i get a deeper tone do i put on a heavyer gage string ?
Heavier gauge strings will make it a little louder but bear in mind that this is an electro-acoustic guitar - you may prefer the sounds of an all-acoustic guitar designed to produce optimum sounds in an acoustic environment.
Aug 11, 2013 • Music
Epiphone EJ 200 CE/AN Electro Acoustic Guitar Wiring Diagram
Does this guitar have a esonic 2 system, if so the other pickup is piezo pickup located under the saddle, there should be two wires coming from the pre-amp just remove the pre-amp from the body and make sure that the two wires are still plugged in and attached to the pickups, these are plugs like a small headphone style plug, just check these and the wires are held in by small wire clips,one of the wires may have came out of the clips...hope this helps I will look for a schematic for you and post it if I find one...Good Luck!!!
Acx1800 no bass very small volume, brand new amp.how do i put my speakers in phase?
If you are sure that the input device (I'm assuming electro-acoustic guitar) is working properly then it sounds like a clear case for return to the vendor! If it is brand new then don't even try to repair it. The phase buttons on the guitar channel are to help reduce feedback by putting the body of the guitar out of phase with the speakers. The speakers should all be in phase with each other though.
When I plug the guitar into an mixing board/amp no sound comes out. From the mixing board, I can see that the mixer is receiving a signal but still nothing comes through the speakers. I own a Fender...
If the mixer is receiving signal, then the problem is pilot error at the mixer, not the guitar. You did not mention what type of mixer you have so I have no way of helping. Common problems would be failure to send the guitar channel to the mixing buss, leaving the channel muted... but we really need the mixer and model number to give more help that that.
2answers
I have a Roland AC-90. During a gig last Sunday I had my Taylor acoustic guitar and a Shure mic cutting out. There would be a break in sound - both guitar and voice would go - and then it would all come...
I would expect there is bad soldering or a circuit board crack. Inspect the soldering aound the leads, especially pots and heavy components. Finding all the retaining screws can be frustrating. Expect the screws for the handle to also attach to the amp chasis. They are often hiodden under plastic caps.
1helpful
I bought my Taylor acoustic/electric brand new. It sounds great, but when i plug it into my amp no sound comes out. I replaced the battery, but it still failed to work. When i plug it in to the amp and...
IF YOUR GUITAR has a built in tuner, make sure the tuner is off as it disables output while tuning... The other thing is to check if you have a volume control on the guitar that might be set too low.. Make sure if you are using 1/4 inch plug guitar cable that it is NOT a TRS balanced cable, as that will turn off the power in the guitar.
Top AMP Music Experts
MrFixitSTTL
ADMIN Eric
ADMIN Eric
Are you an AMP Music Expert? Answer questions, earn points and help others
