Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
"When the power status light flashes red after using the PS3 system for 3
or more minutes and shuts off, the PS3 system has possibly over heated. This
may be caused by poor ventilation or the vents may be blocked."
"If this happens:
· c
Check to see if the vents are blocked. If the vents are dusty,
vacuum the vents to remove the dust.
·If the PS3 system is in an enclosed area like a bookshelf or
entertainment center, move it to a more open area.
·Leave the PS3 system off for 30 minutes to let it cool down.
·If you continue to have issues, you will have to send the system
in for service."
Hope this will help..
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
if there is not even a red light that means that the power supply is gone. find a working one of ebay and install it yourself if your warrantu is expired.
