20 Most Recent RIM BlackBerry Curve 8520 Smartphone Questions & Answers
app error 204,how i can fixied??
RIM BlackBerry... | Answered on Feb 07, 2019
You can unlock any blackberry from any network & after unlocking you can use your blackberry with any GSM provider around the world by just entering one time blackberry which is comes from server, based on IMEI & unique code for every blackberry set. Also unlock any CDMA blackberry using MEID
Unlock 8100 Blackberry IMEI MEP Code
Unlock 8220 Blackberry IMEI MEP Code
Unlock 8230 Blackberry IMEI MEP Code
Unlock 8300 Blackberry IMEI MEP Code
Unlock 8310 Blackberry IMEI MEP Code
Unlock Curve 8320 Blackberry IMEI MEP Code
Unlock 8350 Blackberry IMEI MEP Code
Unlock 8500 Blackberry IMEI MEP Code
Unlock 8520 Blackberry IMEI MEP Code
Unlock 8700 Blackberry IMEI MEP Code
Unlock 8800 Blackberry IMEI MEP Code
Unlock 8810 Blackberry IMEI MEP Code
Unlock 8820 Blackberry IMEI MEP Code
Unlock 8830 Blackberry IMEI MEP Code
Unlock Curve 8900 Blackberry IMEI MEP Code
Unlock Bold 9000 Blackberry IMEI MEP Code
Unlock 9100 Blackberry IMEI MEP Code
Unlock 9300 Blackberry IMEI MEP Code
Unlock 9500 Blackberry IMEI MEP Code
Unlock 9520 Blackberry IMEI MEP Code
Unlock Storm 9530 Blackberry IMEI MEP Code
Unlock Storm2 9550 Blackberry IMEI MEP Code
Unlock 9600 Blackberry IMEI MEP Code
Unlock Tour 9630 Blackberry IMEI MEP Code
Unlock 9650 Blackberry IMEI MEP Code
Unlock Bold 9700 Blackberry IMEI MEP Code
Unlock Torch 9800 Blackberry IMEI MEP Code
Unlock 9900 Blackberry IMEI MEP Code
Unlock Gemini Blackberry IMEI MEP Code
Unlock Javelin Blackberry IMEI MEP Code
Unlock Niagara Blackberry IMEI MEP Code
Unlock Thunder Blackberry IMEI MEP Code
Unlock AtT&T Blackberry IMEI MEP Code
Unlock movistar Blackberry IMEI MEP Code
Unlock T-Mobile Blackberry IMEI MEP Code
Unlock Verizon Blackberry IMEI MEP Code
Unlock Vodafone Blackberry IMEI MEP Code
Unlock Etisalat Blackberry IMEI MEP Code
Unlock Orange Blackberry IMEI MEP Code
Unlock O2 Blackberry IMEI MEP Code
Unlock Cingular Blackberry IMEI MEP Code
Unlock Bell Blackberry IMEI MEP Code
Unlock Fido Blackberry IMEI MEP Code
Unlock Virgin Blackberry IMEI MEP Code
Unlock TELUS Blackberry IMEI MEP Code
Unlock Rogers Blackberry IMEI MEP Code
Unlock Digicel Blackberry IMEI MEP Code
Unlock Cable & Wireless Blackberry IMEI MEP Code
Unlock Telcel Blackberry IMEI MEP Code
Unlock Comcel Blackberry IMEI MEP Code
Unlock Airtel Blackberry IMEI MEP Code
Unlock 3 Hutchison Blackberry IMEI MEP Code
Unlock Claro Blackberry IMEI MEP Code
Unlock Globalstar Blackberry IMEI MEP Code
Unlock Tele2 Blackberry IMEI MEP Code
Unlock Zain Blackberry IMEI MEP Code
Unlock Sprint Blackberry IMEI MEP Code
RIM BlackBerry... | Answered on Jan 10, 2018
The Display (LCD) need to be replaced.
RIM BlackBerry... | Answered on Dec 16, 2017
It may just be time to get a new phone. I didn't even know that BlackBerry phones were still around.
RIM BlackBerry... | Answered on Dec 12, 2017
hi Titchypink.
this is all i could find out,hope it helps you out.
Trackpad, trackball, or keyboard not working on a BlackBerry smartphone running BlackBerry OS 7.1 and earlier Article Number: 000029640 First Published: April 26, 2017 Last Modified: April 26, 2017 Type: Support
Environment
  • BlackBerry smartphones running BlackBerry OS version 6 to 7.1
  • BlackBerry smartphones running BlackBerry Device Software 5.0
Back to top ?
Overview
In some situations, a BlackBerry smartphone with a trackpad or trackball may experience issues with sensitivity, latency, or scrolling. Additionally, the BlackBerry smartphone keyboard, or other buttons may be unresponsive.
Back to top ?
Cause
This issue might be caused by one of the following:
  1. The trackball/trackpad sensitivity needs to be adjusted.
  2. Make sure the trackball/trackpad is not affected by a software freeze or an application freezing.
  3. The BlackBerry Device Software is out of date and requires an update to resolve the trackpad, trackball or keyboard issue.
  4. The physical trackpad, trackball or keyboard hardware is malfunctioning.
Back to top ?
Resolution
Resolution for Cause 1
Complete the steps in Article 5447 to ensure the trackball/trackpad sensitivity is correctly.
Resolution for Cause 2
For BlackBerry smartphones running BlackBerry OS version 6 to 7.1 using a trackpad, complete the following:
  1. From the Home screen, select Options.
  2. Select Typing and Language.
  3. Select Trackpad Sensitivity.
  4. Ensure Audible Roll is selected.
  5. Rapidly roll the trackpad up, down, right, and left.
  6. If an audible click is heard while not responding, proceed to Resolution for Cause 4 as this could be a software related problem.
For BlackBerry smartphones running BlackBerry Device Software 5.0 using a trackball, complete the following:
  2. Select Screen/Keyboard.
  3. Ensure Trackball Audible Roll is selected.
  4. Rapidly roll the trackball up, down, right, and left.
  5. If an audible click is heard while not responding, proceed to Resolution 4 as this could be a software related problem.
  6. If an audible click is not heard, the problem may be related to a hardware issue. Please contact the wireless service provider for additional steps.
Resolution for Cause 3
To update BlackBerry Device Software using BlackBerry Desktop Software see, Article 11320.
or
To update the BlackBerry Device Software on the BlackBerry smartphone visit http://www.blackberry.com/update/
Use the BlackBerry Virtual Expert diagnostics application. For more information, see Article 35973.if not try this link. blackberry scroll pad is not working Google Search
RIM BlackBerry... | Answered on Nov 27, 2017
It sounds like you're having problems with your processor. I would take it into a repair shop
RIM BlackBerry... | Answered on Nov 24, 2017
Install the latest software update from Blackberry and then check the settings.
RIM BlackBerry... | Answered on Nov 17, 2017
Don't do anything! You are being scammed!
RIM BlackBerry... | Answered on Sep 29, 2017
Normally international calls are set up before you change countries. Blackberry will think your phone is stolen.
RIM BlackBerry... | Answered on Jul 13, 2017
I'm afraid the track pad has to be replaced. It goes to full bright from dim screen when you touch it. that's because it sense the touch.but can't sense the direction(scrolling).
But, before that, see if a master reset works. Backup everything before that though
RIM BlackBerry... | Answered on Jun 08, 2017
Do you wear lots of bling.. could it be that you are interfering with the signal due to wearing rings or bracelets etc...?
good luck !
RIM BlackBerry... | Answered on Mar 30, 2017
RIM BlackBerry Curve 8520 Smartphone Logo
1,776 questions posted
Top RIM Cell Phones Experts
RONALD CARTER JR
gggg
Ekse
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
international calls barred traveling in
  • Cell Phones
