It started when we were using convect bake and the fan kept running after we shut the oven off. Then it would just come on and run even though we were not using the range. Then it would go off after some time. I also noticed that when I went to pull the range out today that when I lefted up on the lefdt front corner just below the left most control knob the fan woul stop. It would start again when I released the pressure.
SOURCE: Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
