I forgot to mention that there no remote control for the receiver
I also have the same problem with my Xbox so then i contacted the official Microsoft Xbox live customer support number i.e +1-844-305-0086 so can also call this (Toll Free) number to solve your problem.
Hello, Since the TX-SR502 does not have HDMI inputs you need to connect the HDMI from the XBox 360 to the TV. You can connect an optical cable from the XBox to the receiver if the XBox has an optical output. If not you can connect the optical out from the TV to the receiver. Connect to the optical #2 port on the receiver and press the video 2 button. You should have audio. Thank you, Onkyo USA
Testimonial: "Thank you for the info. I really do appreciate the quick and accurate remedy to my question. When I tried to make the suggested connection I found that the toslink function was not working on any of the inputs so I ended up using the RCA jacks and finally got some sound that wasn't half bad. Once again, thank you for your response. Kevin G."
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR502-Receivers-manual/id/365ag217/t/2/
Search the document for "assign".
