20 Most Recent
Onkyo TX-NR509 Questions & Answers
Onkyo tx-nr509 no sound
check to make sure the speaker wire is not touching on the back of sterio or speakers. then shut off and turn back on. check the menu for speaker a and b and make sure it is turned on
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Need bchdm 0682
I need the PCI of HDMI BCHDM-0682. WhatsApp I have to do to buying it and how much I will have to pay.
Could you answer to
[email protected].
Thank you
Fabio Paceli Anselmo
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
Onkyo nr 555 stuck on recovery:NET
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
