Miscellaneous Logo
m
micheal webber Posted on Apr 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
13 kilometers to miles - Miscellaneous
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Miscellaneous Master 102,366 Answers
  • Posted on Apr 11, 2017
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444354
Points
622693
Kilometers to miles
Multiply kilometers by .6 example '100 kilometers is 60 miles. I always figure so many kilometers and multiply by .6.
If you go 30 kilometers and want miles you figure 30 times .6 equals 18 miles.
Hope this helps.
1helpful
How to go from miles to kilometres on my bmw 320d
A mile = 1.613 kilometers. To find kilometers, multiply the miles by 1.613.
A kilometer = .62 miles. To find the miles, multiply the kilometers by .62.
3answers
What is the speed of an automobile in kilometers per hour if it is trveling 45 miles per hour?
There are 1.609344 kilometers in 1 mile. So you can just put it this way.
45 miles x 1.609344 kilometers
1 mile
The answer is 72.42048 km or just 72.42 kilometers
Therefore the automobile is traveling 72.42 kilometers per hour.
Hope this helps.
2helpful
2answers
Purchased focus sport 2006 model no service manual. Mileage 43,000 kms. Need to know service intervals either time/mileage perhaps a copy of the service schedule will suffice.
These maintenance intervals come from the maintenance interval calculator
at www.autozone.com, using a starting point of 25,800 miles (43000 km), and
assuming 1000 miles (1666 km) driven per month, and "severe driving conditions," which
are actually normal usage characteristics, such as frequent short trips, urban driving, waiting in traffic, driving in hot weather, trips under 16 km in cold weather, etc.
STARTING MILEAGE: 25800 (43,000 Kilometers)
Item
Action
Service History
20000 miles or 32000 kilometers
Battery Check
Oil Filter, Engine Replace
Engine Oil Replace
Vehicle Inspect
Brakes and Traction Control Inspect
Tires Rotate
21000 miles or 33600 kilometers
Steering and Suspension Lubricate
Engine Oil Replace
24000 miles or 38400 kilometers
Engine Oil Replace
25000 miles or 40000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
27000 miles or 43200 kilometers
Engine Oil Replace
30000 miles or 48000 kilometers
Battery Check
Air Filter Element Check
Wheel Bearing Lubricate
Fuel Filter Replace
Engine Oil Replace
Fluid - A/T Replace
Cabin Air Filter Replace
Vehicle Inspect
Cooling System Inspect
Wheel Bearing Inspect
Ball Joint Inspect
Drive/Propeller Shaft Inspect
Exhaust System Inspect
Steering and Suspension Inspect
Heat Shield, Exhaust Inspect
Tires Rotate
33000 miles or 52800 kilometers
Engine Oil Replace
35000 miles or 56000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
36000 miles or 57600 kilometers
Engine Oil Replace
39000 miles or 62400 kilometers
Engine Oil Replace
40000 miles or 64000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
42000 miles or 67200 kilometers
Engine Oil Replace
45000 miles or 72000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
48000 miles or 76800 kilometers
Engine Oil Replace
50000 miles or 80000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
51000 miles or 81600 kilometers
Engine Oil Replace
54000 miles or 86400 kilometers
Engine Oil Replace
55000 miles or 88000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
57000 miles or 91200 kilometers
Engine Oil Replace
60000 miles or 96000 kilometers
Battery Check
Fuel Filter Replace
Spark Plug Replace
Fluid Filter - A/T Replace
Engine Oil Replace
Fluid - A/T Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
63000 miles or 100800 kilometers
Engine Oil Replace
65000 miles or 104000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
66000 miles or 105600 kilometers
Engine Oil Replace
69000 miles or 110400 kilometers
Engine Oil Replace
70000 miles or 112000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
72000 miles or 115200 kilometers
Engine Oil Replace
75000 miles or 120000 kilometers
Battery Check
Fuel Filter Replace
Engine Oil Replace
Vehicle Inspect
Ball Joint Inspect
Tires Rotate
78000 miles or 124800 kilometers
Engine Oil Replace
80000 miles or 128000 kilometers
Battery Check
Engine Oil Replace
Vehicle Inspect
Tires Rotate
And you can continue the pattern from there...
1helpful
2005 cts @ 100,000 what service needs to be done?
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - EXHAUST SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL SYSTEM - INSPECT
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - AIR CLEANER/ELEMENT - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - FUEL FILTER - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - SPARK PLUGS - REPLACE
NORMAL MAINTENANCE @ 100,000 MILES (160,000 Kilometers) - TIRES - ROTATE - [Tires should be rotated every 5000 to 8000 miles, and/or at maintenance I or II service intervals.Check tire pressure, thread depth and wear.]
15helpful
2answers
Tomtom xl340 how do i change from miles to kilometers
Under Change Preferences:
First, Show ALL Menu Options.
Then, select Set Units.
Miles/Kilometers will be the first choice you'll be asked to make.
Ow do you changes from kilometers to miles and where do I get an operator's manual in English?
To change kilometers to miles, divide the number of kilometers by 1.609. To change miles into kilometers, multiply the number of miles by 1.609.
For mavic manuals, go to http://www.tech-mavic.com after you check out this link from Serotta:
http://www.serotta.com/forum/printthread.php?t=6572
How can i solve this problem?
/* REXX is better than JAVA -- see: http://www.REXXLA.org */
say 'Welcome to the class named DISTANCE'
pull kilometers junk
if kilometers = ' ' then exit
conversion = 0.62137
miles = kilometers * conversion
say kilometers 'Kilometers is' miles 'Miles.'
exit
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
