The television was made in the 1990's and does not have the needed connections that new game consoles require. You need one of these: http://www.gamestop.com/xbox-360/accessories/pelican-xbox-360-rf-adapter/42229
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
SOURCE: how can i turn on the av channel on a sony trinitron KV-25F1U
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
Testimonial: "thank you so so much, so simple but I dont have an instruction manual. Many, many thanks. Angie"
SOURCE: sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
