Key won't come back up on Roland digital piano
Roland FP is a nice keyboard but has a known problem on cracking key weights. There is a counter weight under each key to push the key upward. There are two sizes of weight beams, longer one for white keys and shorter one for black keys. Roland did not make the original weight beams strong enough to last. They will crack and eventually break. When it happens, the key will stay down. Fortunately, they can be easily replaced.
Roland FP-8 has 4 black screws at the bottom on each side end. Remove the screws, flip the ends up and expose the interior. Near the hinge of the problematic key, carefully ply open the hinge tabs and remove the key from the hinge. You will find a weight beam under the key. Remove and inspect the weight. There should be a metal wrapped in a plastic beam. If the metal part is missing, find the missing part and replace with a new beam. You can order weight beams from Roland. It costs about $10 each plus shipping. Put everything back in the reversed order.
