Tools & Hardware - Others Logo
W
Walter Posted on Dec 26, 2016
Craftsman rotary tool 572-610030 exploded view to see where and how the spring is positioned on the collet lock.The picture has to be quite large.
5 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Jul 02, 2009
SOURCE: i would like to know if dewalt has any collets for
go directly to their service site at Dewaltservicenet.com and type in your model number and you will see what is available for it. Then you can also check to find a center or repair facility near you.
Anonymous
  • 202 Answers
  • Posted on Jul 07, 2009
SOURCE: Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Anonymous
  • 2176 Answers
  • Posted on Oct 03, 2009
SOURCE: Kawasaki Rotary Tool is missing the square collet nut
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Anonymous
  • Posted on Dec 07, 2009
SOURCE: Can't find replacement collets/locknut for PowerSmith rotary tool
Hello Bob, I recently saw your post about the Power Smith PS2103. I have this same tool, and have never been able to use it because the collets don't fit the bits.
I was looking at it recently - I have the owner's manual - and although there is no web address, there IS a toll free help line. Here is the number - 888-552-8665
I called the number - got their voice mail, left a message, but they have NOT returned my call!
The only outlet that MAY carry this brand is Zellers, but I haven't been there yet.
Good Luck!
Bob (in Canada)
[email protected]
Anonymous
  • Posted on Dec 21, 2009
SOURCE: I have a Durabuilt rotary tool model S1J-FE2-10
I have the same problem with mine. The collet nut that came with it is too big. It wont screw down to hold the collet. I am searching for a new nut.
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
1helpful
How do I change parts, i.e. from grinding wheel to sandpaper wheel?
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
How to use the collet wrench
There should be a spindle lock near the collet end of the tool. Engage it and then put the wrench on the collet nut and loosen the nut. If the bit is stuck just tap the end of it slightly to loosen it and it should come out. Reverse this process to install a new bit...hope this helps you...Jeepfxr
11helpful
3answers
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
1helpful
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
2answers
1helpful
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Top Rotary Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
