20 Most Recent Craftsman Single Speed Rotary Tool Questions & Answers
I can't get the small
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
8/11/2011 5:00:57 PM • Craftsman Single... • Answered on Aug 11, 2011
I was in the middle
A new switch is available from Sears Service centers or from sears, online.
5/13/2011 4:21:33 PM • Craftsman Single... • Answered on May 13, 2011
How do I change parts, i.e. from grinding wheel to
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
3/16/2011 11:25:44 PM • Craftsman Single... • Answered on Mar 16, 2011
3answers
Coupler between motor and chuck disintegrated,
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
$2.57 In stock
5/29/2010 9:59:40 AM • Craftsman Single... • Answered on May 29, 2010
Crafatsman Rotary Tool Single speed - chuck has no power -
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
5/29/2010 12:30:32 AM • Craftsman Single... • Answered on May 29, 2010
I have a rotary tool single speed chuck does not
Common issue with these, the plastic flex coupling is broken-
Replacement available for $2.57 from
Number: 2615294309
Weight: 0.18
Disassembly on my model involved the following:
Remove the four Torx screws on the body, then unscrew the front end cap at the front of the tool to expose two more screws. Separate the two halves of the body to see the brittle and broken yellow coupling.
Replace with the new white coupling and reassemble. Buy spare couplings as they don't seem to last all that long.
5/19/2010 3:27:49 AM • Craftsman Single... • Answered on May 19, 2010
My craftman single sped rotart tool the chuck with
Do you have any kind of a clutch on this drive ? I may be in bewteen settings.
Please let me know
2/6/2010 6:40:24 PM • Craftsman Single... • Answered on Feb 06, 2010
2answers
Where can I find a manual for a craftsman nail gun model 58368429
Craft store
11/21/2022 7:53:51 PM • Craftsman Tools... • Answered on Nov 21, 2022
We are looking for staples for a Sears Craftsman Heavy duty staple gun (manual not electric)
If you google Heavy Duty Wide Crown 3/8 in Wire Staples there are hundred of sites that sell the staple amazon, Home depot, Lowes, Walmart
11/2/2021 6:49:11 PM • Craftsman Tools... • Answered on Nov 02, 2021
I need a diagram of the craftsman stapler 968514
1/29/2019 3:24:49 PM • Craftsman Tools... • Answered on Jan 29, 2019
I purchased a 320.27683 router and table. I am using craftsman 1/4 in bits. The 1/4 in collet nut will not tighten the bit . The bit just pulls right out. I left 1/8 space between the bottom of bit.
Take the collet fully apart and clean out all sawdust and other debris. Does this happen on all i/4 shank bits? use only quality bits preferably American bits. I use Whiteside and Amana, Cmt is a good bit. If it does not hold any 1/4 bit replace collet. To my knowledge Sears has never made a router, they just sell them. It's possible it was a Skill, a Black and Decker, or some other common brand with a few specs that Sears had them made with (good luck with that). Check router forum.com other people have looked for collets, there is many suggestion or answers. t site has them, but it does not specify 1/4 or 1/2 OEM Craftsman Router Collet Asy 2823121000 Ships Today Fix com
11/10/2018 7:24:17 PM • Craftsman Tools... • Answered on Nov 10, 2018
How do I change the belt on a Craftsman 3"x21" belt sander, model 31522580? This one is pretty old but still works. I couldn't find a manual anywhere for it.
First, I'm not a Sears Tech (ahh, not Lowe's either.) * Sears Parts; https://www.searspartsdirect.com/model-number/31522580/0247/0743000.html?searchType=modelSearch&q=31522580&searchTerm=31522580 * You can also look at the old belt and get the numbers off them. Check on Amazon.com for replacements. Aloha, ukeboy57
7/10/2018 10:43:56 PM • Craftsman Tools... • Answered on Jul 10, 2018
Craftsman Single Speed Rotary Tool Logo
Popular Tags
11 questions posted
Top Craftsman Tools & Hardware - Others Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Tools & Hardware - Others
Most Popular Question
change parts e from grinding wheel
  • Tools & Hardware - Others
