20 Most Recent Rotary Thumlers Tumbler Polisher +media,rocks Questions & Answers
3answers
My tumbler won't turn. Tried unloading some rocks
I had the same problem, The problem is that the tumbler lid is to smooth and there is no grip from the spinning wheel. I solved this problem by taking a kitchen steak knife and roughing up the edge of the tumbler where it rides on the spinning wheel. Works great now. Best of luck
12/27/2023 5:18:27 AM • Rotary Thumlers ... • Answered on Dec 27, 2023
I bought my son a
I can't find anything for the NatGeo Rock tumber ( I assume it is National Geographic) but I did find a site that has free instructions on how to use a tumber and hints for the best results, The site is Geology.com and they have I hope the information you need. I wish I had better results.
4/9/2017 9:13:03 AM • Rotary Thumlers ... • Answered on Apr 09, 2017
0answers
0answers
Rolling Stones Rock Tumbler - no rubber ''O'' ring
Nothing high tech here. Try it without the o-ring. If the water does not start to leak out in the first 3 to 5 minutes of tumbling you will be ok. Stop it every day to check the water level.
Set the whole thing on a cookie sheet in case it does leak when you are not watching - you don't want a bunch of rock dust and polishing grit on your table or floor in the morning.
You will not damage anything by trying it without the o-ring.
3/18/2010 3:23:30 AM • Rotary Thumlers ... • Answered on Mar 18, 2010
I just bought my Hyper Tough rotary tool and used it once for 5 minutes. Now it won't turn on. What is wrong with it and can I fix it
Send it back, it is under warranty. Try giving it a tap to settle the brushes. Also, it may have cut out on a thermal fuse. Wait 15 minutes and try again. Dremel are the brand leader for good reason :>D
4/8/2022 11:22:14 PM • Rotary Tools &... • Answered on Apr 08, 2022
Sears model 572.248920 need flex coupling 529430970
sears.com --online search
1/21/2022 1:04:45 PM • Rotary Tools &... • Answered on Jan 21, 2022
Where can I find model number of Wecheer rotary tool? I need a owner's manual.
Click here first https://wecheer.com/ Then click Rotary Tool and Accessories They are all different visually by model number Then Google Make model manual and you will end up here wecheer.com > man
PDF WECHEER Heavy Duty Power Tool is a recognized and approved system by CSA authority. It can be used with hundreds of different rotary tool accessories for ...
11/11/2020 9:56:27 PM • Rotary Tools &... • Answered on Nov 11, 2020
My hyper tough cordless rotary tool keeps stopping. It will only work for 5 seconds and it goes off and yes the battery is charged.
Some kind of jamming might be creating the problem. After 5 secs. tool heats up enough to make the auto shut off to work.
4/5/2020 1:05:19 PM • Rotary Tools &... • Answered on Apr 05, 2020
Users manual for hyper tough cordless rotary tool model# AQ85000G
Just Google manual for your make & model
7/11/2019 8:55:41 AM • Rotary Tools &... • Answered on Jul 11, 2019
My craftsmen rotary tool is getting to hot to hold, do they need oiling?
Sounds like it has a build up of dust. They need to be blown out with air from time to time
5/1/2019 1:00:30 AM • Rotary Tools &... • Answered on May 01, 2019
How to use/install cut off wheel to 1/8 shank in 63235 rotary tool set.
Find the instructions and you will find the answer. http://www.manualsonline.com/
2/28/2019 12:02:16 AM • Rotary Tools &... • Answered on Feb 28, 2019
Rotary Thumlers  Tumbler Polisher +media,rocks Logo
Popular Tags
11 questions posted
Top Rotary Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Rotary Tools & Hardware - Others
Most Popular Question
tumbler turn tried unloading some rocks
  • Tools & Hardware - Others
