20 Most Recent
Rotary RotoZip XB-LF5 Laminate Flooring X Bit Questions & Answers
How to lay laminate flooring
start against your longest wall. clip three rows together and slide lightly against the wall. put shims of wood in the gaps between the wall and new floor to make it solid. continue adding planks from there.
I have had new laminate flooring installed and
Well it depends on the situation, and I'm not sure of the situation by what you told me. If the gaps are in the laminate floor I would use wider molding to cover to the gaps. I have also found silicone caulking to work well in situations where there are gaps as it remains pliable and last a long time without cracking. Make sure if your going to use it you buy 100% silicone, and I have found GE brand silicone caulk to work the best in all situations.
