e
ehsun Posted on Dec 04, 2016
Hi i forgot my pincode... how can i off or remove the pin??
My projector is sony es5
5 Related Answers
A
Anonymous
  • Posted on Nov 19, 2007
SOURCE: i forgot my answerphone pin code
same...try taking it to like an unlocking place...i am sure mobile phone shops know a couple nearby! Good luck...
Anonymous
  • 104 Answers
  • Posted on Jan 21, 2008
SOURCE: pls help
press call, *, 3 and power button at the same time, wait until formatting apear on the screen.
Anonymous
  • 5 Answers
  • Posted on May 29, 2008
SOURCE: pincode blocked
ya just call your costumer care n tell them that ur pin code is blocked.but before that u should jus take out ur sim card n note the number on backside of sim.because they'l ask u for that.go ahead.
otacon
Damen Wong
  • 1950 Answers
  • Posted on Jun 09, 2008
SOURCE: my sony ericsson cell is asking a pin code
If the code hasn't been changed, then try 0000 and 1234
Anonymous
  • Posted on Feb 22, 2011
SOURCE: Hi My Sony VPL ES5 SWITCHES OFF THE LAMP AFTER 2
hi your projector probaly has done around 2122 hrs on the bulb just reset the lamp timer and you should be good to go ps this worked for me (answer yes to replace bulb and clean filter then press ok pps might be a good idea to start saving up for a replacement bulb hope this helps cheers !!!
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
I forgot my pin codehow to get back pincode to my pldt telpad
pin cod means, its a service provider problem, pin code is related with sim card, contact to customer care on your service provider,...
thanks....
Dec 01, 2014 • Cell Phones
How do I fix Lamp/Cover flashing light?
There is a switch or a button that gets depressed when you close the lid of the lamp compartment. See if the plastic of the lid is broken or not hitting it right. Not screwed down right or the lamp is not seated all the way down.
Sony projector vpl es5 goes off after shot time of powering whats the cause
two reason
1,fan
2,lamp
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
How to remove my pincode on my nokia fone unit 1280 coz i forgot my pincode
Kindly put wrong pin many times approx 10 times then you will get puk error. Call your customer care for getting puk number from other phone having same service providers sim then you will be able to get inside your phone.
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
1helpful
Hi My Sony VPL ES5 SWITCHES OFF THE LAMP AFTER 2 MINUTE
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
