SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
SOURCE: My reciever is flashing the
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
SOURCE: my reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
SOURCE: sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE405-Receivers-manual/id/387bh944/t/2/
and refer to the manual that should have come with your unnamed subwoofer.
