Washing Machines Logo
Tracy Pickett Posted on Nov 12, 2016
I have a wdd760 washer dryer and it doesn't start when I've set the delay timer button and the remaining time on display doesn't change. I've left it unplugged over night.
1 Related Answer
BLACKSCOR203
  • 22 Answers
  • Posted on Nov 10, 2016
SOURCE: The time on my hot point washer dryer wdd760 is wrong and when I set a delayed time it hasn't come on? B
unplug your machine over night. in the morning plug it back in. This should reset the internal clock. Many manufacturers using digital technology did not account for daylight savings time and your machine may be adding or loosing time (neuclear clock was not programmed into your circuit board)
2answers
EdgeStar DWP61ES turns itself on and off, display shows H:01 then counts up through H:24 then either turns off or starts the count again.
Many owners of the Bosch dishwashers perceive h01 (h: 01) or h02 (h: 02) and other signs as an error. But in fact, this is not an error, and you accidentally got into the start-up timer menu (delayed start of washing dishes). In this case, h01 means that washing dishes will start exactly in 1 hour; if the display shows h02, then washing process will begin exactly in 2 hours. As a rule, in most models of dishwashers from Bosch, a delayed start can be set in the range from 1 to 24 hours.
Timer programming You can delay the start of the program in 1-hour steps up to 24 hours.
  1. Close the door.
  2. Switch on ON/OFF switch [1].
  3. Press button [4] + until the digital display [9] jumps to h:01
  4. Press [4] + or - button until the displayed time corresponds with your requirements.
  5. Press START button [6], timer programming is activated.
  6. To delete timer programming, press the [4] + or - button until h:00 is indicated on the digital display [9].
You can change your program selection at any time until the program starts.
FOR LINK https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-h01-h02/
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself!
First u need to set the length of cooking time, eg 2hrs.
Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00.
THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs
The display should then revert to the present time.
THEN turn the oven control to the required temperature.
The oven will switch on at 1530 hrs.
If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining.
AT 1730, the oven will switch off and the alarm will sound
To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN
REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow!
HOPE THIS HELPS
I would suggest first.trying it when you're at home all the time the oven is on.
7helpful
2answers
I don't know how to get/find/use the timer on my camera FINEPIX SL245
Press cursor-down (marked with a one-handed clock) to bring up the self-timer menu, use cursor-left/right to select the desired delay, then press the MENU/OK button. Start the self-timer by pressing the shutter release button as usual.
Full details are in the "Using the Self-Timer" section of the manual (page 39 in my copy). If you need a manual you may download a copy here.
Jan 28, 2013 • Cameras
1helpful
2answers
Setting timer on window unit to turn on and off
Hi Jessica Yacopino - Generally speaking, Frigidaire air conditioners timer option typically have the same procedure. The unit must be in the ON position for the timer delay stop option. For delay start, the unit must be in the OFF position. First, press time button. Then to adjust timer setting, tap or hold the UP arrow or the DOWN arrow to change delay timer at .5 hour increments, up to 10 hours, then by 1 hour increments up to 24 hours. The control will count down the time remaining until start (8, 7.5, 7, etc.). The Delay Start mode automatically selects cooling with maximum Fan Speed. The temperature maintained will be the same as previously set. To change the set temperature, press "COOL" then Up or Down arrows until the desired temperature is indicated on the display. After 5 seconds, the control will automatically change the display back to the hours remaining until the unit will start/stop. PRESSING the unit On/Off button at any time will cancel the Delay Start/Stop function. The Delay Start/Stop Feature will work until the unit either starts or stops. Once that happens the above steps have to be repeated again.
2answers
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
2helpful
How to set self timer?
Hi.
1. On the outside of the cameraPress the 'function set' button marked chas6_15.jpg.
2. Use the 'up'/'down' buttons to select 'Drive Mode' chas6_13.jpg in the display.
3. Use 'left' / 'right' buttons to change the self-timer mode.
4. Choose the timer delay or select chas6_14.jpg, after which pressing the 'Disp.' button will allow you to set the delay and number of shots.
5. Press the 'function set' button again to start the timer.
Hope this helps!
Dish washer does not turn on CL light stays on when reset count down 6 appears then goes to CL
Hello and welcome to Fixya,
I have a ton of service info on Bosch so it`s best I post you an exert from the service pdf`s I have on my PC which will explain the meaning of "CL" and then go from there. This is not a common indication of a control problem, but it could be a problem with the plastic casing which houses the control, we`ll deal with that later.
I`ve underlined the section pertaining to the "CL", this is for the SHU68** dishwashers only.
TO OPERATE:
First depress the On/Off Button until it locks in place.
Once the On/Off Button is depressed the LED above the previously used cycle will illuminate.
To change the cycle, simply press the desired Cycle Button twice. The LED above that cycle will then illuminate.
The Cycle Countdown will display an approximate run time for the cycle chosen.
This run time will depend on incoming water temperature and the turbidity of the pre-wash water.
Note: It is normal for the Countdown Display to remain at a time increment for more than one minute, or skip a time increment depending on the calculations of the Control Unit. Also, with continued use the Control Unit will learn the wash and temperature patterns for the most commonly used programs and will then reduce the overall start and running times.
At the end of the cycle the display will show a CL, indicating that the cycle is complete.
**TO CANCEL A CYCLE:
Press the Scrub Wash and Delicate / Econo Buttons both in at the same time. The unit will then drain and the figure CL will appear in the display.**
DELAY START:
The Delay Start feature allows the unit to be delayed for up to nine hours. To program, start the unit as described above, but after selecting a cycle push the Delay Start button. The display will show a 1h, or one-hour delay. Continue to depress the Delay Start Button until the desired delay time is reached (up to nine hours, 9h).
The unit will begin automatically once the delay time has elapsed. To reset the delay, press the Delay Start Button until it reaches 0h.
TOP RACK ONLY:
The Top Rack Only feature can be used in conjunction with any cycle. To active, press the Top Rack Only Button after selecting a
cycle, the Top Rack Only LED will illuminate and all water will be diverted to the upper wash arm for the complete cycle.
REFILL RINSE AGENT LED:
The Refill Rinse Agent LED is activated via a Reed Switch on the Detergent Dispenser, Section 4, Fig. 8-3. The LED will
illuminate when the Rinse Agent Dispenser is empty.
Service note: The Refill Rinse Agent LED will also illuminate when the dishwasher door is opened and then
closed even if the Dispenser is full, but will only remain lit for a few seconds.
“F” CODE:
An “F” in the display window indicates a filling fault.
Please note: If the door is opened during the cycle, the On/Off Button will be reset to off and must be depressed again to re-active the cycle. The cycle will resume from where it left off.
Now that you are equipped with this info, what I`d suggest is trying the **cancel option. ( ** see above )
Once you`ve tried the cancel option, select a Regular Wash and post back what happens and I`ll try to assist you from there.
Good luck.
macmarkus :)
Timer delay displayed permanantly and beeping
the button is not stuck in is it? sometimes they get a bit sticky in kitchens.
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Top Washing Machines Experts
john h
