SOURCE: constant clicking when turned on
I installed a brand new Jenn air gas cook top 9 with (AUTOMATIN RE-IGNITION) and it did the exact same thing. Per Rotu's suggestion I plug it to an outlet from the living room (not GFCI Circuit). The problem goes away. Thanks ROTU
SOURCE: kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
SOURCE: my ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium. If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas. After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up. The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel. Lift off and unsnap the casing of the problem igniter switch. The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
