20 Most Recent GE 30 in. JGP337 Gas Cooktop Questions & Answers
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
GE 30 in. JGP337... | Answered on Nov 14, 2013
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
GE 30 in. JGP337... | Answered on Jan 23, 2013
Some ranges have the conversion orfices right on board and for others you will need to order a conversion kit. Your manual will have the directions if the kit is on board. If there is no directions then look at most any of the appliance parts websites under your model number for the conversion kit.
heatman101
GE 30 in. JGP337... | Answered on Apr 21, 2011
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
GE 30 in. JGP337... | Answered on Aug 30, 2010
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
GE 30 in. JGP337... | Answered on Aug 21, 2010
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
GE 30 in. JGP337... | Answered on Aug 18, 2010
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
GE 30 in. JGP337... | Answered on Aug 15, 2010
take the part back and get the correct one. yours may have been packaged wrong
GE 30 in. JGP337... | Answered on Feb 18, 2010
You have one of your spark switches sticking. It may have come loose or possibly grease has migrated into it.
Remove the switch panel and check the switches for a loose or broken switch.
There is a switch behind every surface burner knob.
They must be seated firmly to work correctly.
GE 30 in. JGP337... | Answered on Nov 26, 2009
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
GE 30 in. JGP337... | Answered on Jul 24, 2009
Call GE answer center 1-800-626-2000 aek for tech help. Have you Model # off your data plate ready.
GE 30 in. JGP337... | Answered on May 09, 2009
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
GE 30 in. JGP337... | Answered on Jun 29, 2008
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
GE 30 in. JGP337... | Answered on Apr 27, 2008
GE 30 in. JGP337 Gas Cooktop Logo
27 questions posted
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
switch from lp gas
  • Cooktops
