Thans\ks for the call,
The common issue in these stove tops when the ignition system does not turn off is the spark control module itself not detecting the the ignition system sucessfuly ignited the gas. This prevents gas excaping without combustion. This module is located depening on how its set into the counter toward the back. There are two wires one negitive and one positive, Thus this goes into a module then diverted to each of the burners.
You did expess you would rather have someone work on your unit because of your knowldge doing this work yourself. I would highly suggest a service call from a appliance tech that is certified with this type of work. Working with GAS is dangerious and could cause injury, Fire and death if safty is not reconized.
I would not recommend anyone that is not licenced with your state. Check them otu first before you make that call.
From al the information your telling me the module would be your issue. Now if there was something left out of the information your telling me you might need more parts.
Once again it was my pleasure working with you today.
Regards,
Rulds2008 Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
