Two different options,... Call the extension, and while it is ringing, press the volume down bar until you can no longer hear it ringing. You can also try this... Leaving the handset down, do Feature * 80, adjust the loudness for ringer volume by pressing the volume bar.
Testimonial: "Unfortunately that only takes it down a little. I need to turn the volume off. Thanks!"
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
It should turn it all the way down so that you don't hear it. As the phone is ringing, try pushing and holding the volume down bar until you can no longer hear it.
