KitchenAid Kitchen Aid KL26M8XOB - Pro Line Series Stand Mixer, 6 qt, Pouring Shi Logo
Deb Doan Posted on Oct 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After cleaning my kitchen aid mixer it won't turn on
I took my mixer apart to clean it and now it will not turn on.
Marvin
Level 3:
Top Expert:
  • KitchenAid Master 85,242 Answers
  • Posted on Oct 17, 2016
Marvin
KitchenAid Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060200
Points
266281
You must have water in the controls, use a blower dryer and dry it all out or just let it set for a few days and see if it works again, if not you must have done something wrong assembling it, what that might be is really hard to say.
Kitchen Aid Mixer. How to fix a grinding sound when switch is on Medium speed?
Question edited for clarity.
The drive train probably need cleaning and re-greasing, but there is also a gear that wears out.
https://www.google.com/search?q=Kitchen+Aid+Mixer.+How+to+fix+a+grinding+sound+when+switch+is+on+Medium+speed
Dec 26, 2023 • Food Mixers
Kitchen aid mixer ksm150ps won't turn on
See following video. Fast forward to 7:30 and it shows the on/off contact. Around a minute earlier it shows the the speed lever, spring, and link.
https://youtu.be/Pi8ufwlOtqU
Kitchen aid oven door glass
nor do we photos being taken while taking apart usually helps
Change oil kitchenaid mixer
They do not have oil in them, it will be the grease breaking down. It is food grade grease so not at all harmful. If you want to replace the grease you will need to pull the mixer apart and clean out the old grease and purchase some new grease from Kitchen Aid, a very messy job.
1helpful
Kitchen aid model kb25gixob will not turn on.any suggestions?
Put an ohmmeter across the two pins on the plug, on the mixer,,not the earth one.and turn the switch on.you should get a reading,plus it will change as you turn the switch to different settings.if no reading,suspect broken wire in plug,or mixer windings burnt out.try in a different socket
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
1helpful
The speed lever on my KSM 90 won't lock in the off position.
Do you have a manual? You can download one from Kitchen Aid, small appliances. There should be a schematic and how to that will help.
No power to my kitchen aid mixer
please i need help kitchen aid mixer i have no power
KITCHEN AID MIXER K5SS has a banging noise when turned on how would I find out how to fix it ?
You will need to open it up and inspect the brushes carefully. Look for a little copper wire, this wire needs to be firmly attached to both the brush and the little disc at the other end of the spring. Clean the brush out with a can of electric cleaner to free any dirt that has built up around the gears.
1helpful
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
