20 Most Recent KitchenAid Pro Line Coffeemaker Coffee Maker Questions & Answers
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
KitchenAid Pro... | Answered on Oct 31, 2014
Sounds like it is broken. Should be under the manufacturer's warranty. Go to the store and get it exchanged. Or contact KitchenAid.
KitchenAid Pro... | Answered on Sep 13, 2011
I have the same problem of corrosion under the finish near the water filling section.
KitchenAid Pro... | Answered on Feb 28, 2011
Hi, the only distributor for Kitchenaid Pro Line parts is Kitchenaid directly. I would recommend calling their customer service. They have a specific parts department. Their toll-free telephone number is 1-800-541-6390 and they will also help you on how to replace it yourself..
KitchenAid Pro... | Answered on Feb 03, 2011
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
KitchenAid Pro... | Answered on Oct 24, 2010
I2 have same. Problem = not a nozzle missing, but a black plastic diffuser mounted below the orifice. Plastic becomes brittle and disintegrates within weeks. Pieces fall into grounds so you may never notice. Photo is of pieces I recovered from the grounds. Horribly bad bit of engineering on an otherwise great product. (Saved how much over cost of stamped stainless?) I have not been able to find replacement part, although OEM piece would fail again within weeks. ALL ProLine makers MUST fail in the same way - the plastic part CANNOT survive actual use. KitchenAid should offer steel replacement! ad74f59.jpg
E2 error
Out of warranty because I bought it used.
You can use a solution of white vinegar and water, and run it through the machine, or buy a de-scaler at many home appliance stores and coffee specialty stores. Try sweetmarias.com.
KitchenAid Pro... | Answered on Oct 16, 2010
making coffee very wet? sorry have no idea what u mean by this statement, please clarify this statement, coffee is a liquid composed of water.
KitchenAid Pro... | Answered on Aug 03, 2010
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
KitchenAid Pro... | Answered on Dec 21, 2009
KitchenAid Pro Line Coffeemaker Coffee Maker Logo
38 questions posted
Top KitchenAid Coffee Makers & Espresso Machines Experts
graybeard32301
Ismael Rodriguez...
Steve Allison
Steve Allison
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Coffee Makers & Espresso...
  • KitchenAid Coffee Makers & Espresso...
Most Popular Question
e2 error code
  • Coffee Makers & Espresso Machines
