It has function similar to Beko, I did same test mode of Beko washing machine (hold start/pause button and then press ON button), the error that displays is E07, any program I try it remains the start led flashing until end of program but nothing happened. I already change the pressure sensor. Note about test: When I try the test mode, after the filling (step num.6), at the moment of washing machine drain, the test failed (It's my opinion) , becouse it not drains out water through the hose but the washing machine loses water below, in central areas of it (not near pomp filter)
SOURCE: hotpoint washing machine Aquarius WD640
Try this sequence; Hold down start and cancel button together, TEST should disappear of display,
Then hold down START/ CANCEL, and ON/OFF at the same time.
The message D/off should appear in the display, it should then work.
If it does not then the main pcb is likely to be faulty..
That will mean calling an engineer.
Pleas rate my fixya solution.
Thankyou.
SOURCE: Washing machine quit towards the
www.managemyhome.com is a site run for sears. You can check there for more help
SOURCE: blomberg washing machine
I have a blomberg washing machine AAA rating with "fuzzy logic". Now it is not working, will not fill with water or spin, but you can see the dial turning and going through the dial settings. Whats wrong. Can anyone help and I have lost the manual.
Carla
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
SOURCE: beko washing machine main wash led flashing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
