Dark screen since new
Wow only 10 then major work, hum. First if pic is:Split screen picture with one half darker than the other half. "Deep Field Imager" is set to the demo mode, press the "video" button repeatedly to cycle through the video settings until Deep Field Imager is accessed and then change the setting from demo to "on" or "off" depending on preference. Also u can try:1. Dark blue raster with faint movement in the background, suspect the FMT PCB part # 934C153001 . Also1. May be intermittent. Remove and reseat the DVI cable between the Chassis and Optical engine 2. Removing and reseating the DVI cable does not resolve, replace the Optical Engine part # 938P015020 Hope this helps Tom!!
