20 Most Recent
Lowrance iFinder GO2 Handheld GPS Receiver Questions & Answers
If I get a new Lowrance GPS, can I use my SD card
First use "add gps" and add the original unit and the H20use "receive from gps" to call in the original waypoint file from your sd carduse "send to gps" to save the new waypoint file to the sd cardremember that the original gps file may contain more waypoints than the H20 can hold so you may have to delete some waypoints from the file while in EasyGPSif this is not clear enough, let me know and I will try again. I use the program all the time. I just realized I left something out. EASYgps does not like the Lowrance HDS File version so an extra step is required if you are transferring files from an HDS to an IFinder. Save your HDS waypoints as Version 3 to the SD card and EASYgps will accept them
Lowrance 5200c wont display Navionics map.
Please test the backup sd card on another GPS if possible to see if the zoomed-in section of the map file shows up or not. If it shows, then you'd need to send in your lowrance gps for repair from the water damage.
Thank you.
11/11/2022 3:21:31 AM •
Lowrance GPS
Answered
on Nov 11, 2022
