20 Most Recent Mitsubishi WD-62528 62 in. LCD Television Questions & Answers
The green light flashes on, will not power up even
i changed the lamp and now the yellow light is flashing
1/4/2020 7:40:27 PM • Mitsubishi... • Answered on Jan 04, 2020
Where are the capacitors that need replacement located on the Mitsubishi WD-62528.
Look for ones that are bulged on the tops and replace those, if you don't see any bad ones your going to need a ESR meter to test them
1/7/2018 8:24:37 PM • Mitsubishi... • Answered on Jan 07, 2018
0answers
I need to add my Ps4 system thru the hdmi connection on my Mitsubishi tv (Diamond series)
The ps4 should have a menu that selects HDMI INPUT .
5/29/2015 7:14:44 PM • Mitsubishi... • Answered on May 29, 2015
TV will not turn on. Lamp indicator light is
This is fairly typical of a main power supply failure. There are (at least) two supplies in your set; one of them is on all the time so the set can respond to remote signals. The other (and the possible third) is turned on when the set is used.
If you feel adventurous, comment back to this thread and I will provide some guidance if you no longer have any warranty coverage.
8/19/2014 1:27:13 AM • Mitsubishi... • Answered on Aug 19, 2014
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
5/17/2014 6:09:50 PM • Mitsubishi... • Answered on May 17, 2014
0answers
Replace 62" tv screen
It is very skilled work. Contact the authorized service center for Minsubishi. You can't get this panel nowhere by the open electronic spare part market. Gopakumar Gopalan Google
4/24/2014 2:04:55 PM • Mitsubishi... • Answered on Apr 24, 2014
0answers
My mitsubishi wd60735 turns on for ten second and than shuts off and bothe a red and green light flash
As I've said in other posts, flat panel tvs that come from china have cheap capacitors in them that eventually break. Usually in the power supply area, where a reference ic monitors a voltage. And if and when a capacitor fails, and the voltage drops below the ic's reference point, it will not turn on the television. Fix is to replace ps Capacitors with exact values. Boards are modular, so you shoud be able to unplug and replace capacitors on ps board. Of course, be careful with connectors. It's only in the ps area of most flat panel tv's where these main capacitors break (or dry up).
2/2/2014 10:11:36 PM • Mitsubishi... • Answered on Feb 02, 2014
0answers
Mitsubishi WD-62528 62 in. LCD Television Logo
68 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
picture very dark brightness
  • Televison & Video
