I find that when I sew with the foot peddle, the machine contiunues to sew when I take my foot off the peddle.
SOURCE: i can't sew on my machine
I had the same problem.There is a gold or silver washer on the back of the sewing machine that holds the part inside that you are connecting to. If the washer is gone or loose you will not get a connection when you insert the foot peddle. This peice inside is small and square with three delicate wires attached, You should be able to see it
SOURCE: sewing machine Brother Cs-6000i don't work
let me know too, mine won't turn on, worked just fine yesterday, Suz
SOURCE: brothers sewing machine ls 1520
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
SOURCE: F4 error on my brother cs-80 sewing machine
Can't answer your problem, my problem also. But I don't have the auto button, so I am really stuck. Was hoping you got the answer and did not have time to post.
Amy
