Sony DVP-SR200P DVD Player Logo
A
Anonymous Posted on Sep 12, 2016
How do i to put the dvd on region free code? - Sony DVP-SR200P DVD Player
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Sep 12, 2016
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008283
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock televisions and DVDs"; in the search box at the top left of the display window, to get gathered related posts.
2answers
Dvd wrong region
Not all DVD players can be used in different regions, yes there is a code you can use to enable use in different regions depending on the unit. If you access the "setup" menu from your remote you may be able to select the region but I believe this player is only supports US NTSC TV standard if you bought it in the USA and JPG for photos.
Wont support dvd
DVD REGION FREE & BLUE-RAY REGION FREE
To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
4answers
1helpful
2answers
I have bought Pioneer DVD player 420V few days ago, but when I put disc I got message on the TV that DVD can not play because the region code is not recognized. Should I reset all systems or???. I need...
the region code means the player does not support the disc your playing each country is given a region code for dvd australias is region 4 if you buy a dvd from another country it wont work you can get multi region codes for dvd players im not sure of pioneers code but try using a dvd from your country region and youl find it works just fine you can also try asking a tech on fixya for the multi region code for the model dvd player you have.
best of luck
merry christmas
1helpful
2answers
Need region code to unlock LG dvd home theatre HB905PA
If you live in the US your region code is 1
if you are able, put in 0. this will allow you play DVD's from all over the world regardless of region code on the particular DVD.
DVD region code
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
1helpful
4answers
Cannot play my dvd,s in my geoghraphic region of the world.
There are a couple ways to go about changing your region on your DVD player. First is this program:
DVD Region+CSS Free - Watch & Copy Any DVD!
US$ 39.95
dvd-region-free-b.gif Tell Friend
DVD Region+CSS Free enables you to watch and copy any region-coded/CSS-encrypted DVD movies on any DVD drive! It fully supports region-protected (RPC2) DVD drives, and does not require any firmware modifications. It will even work if you have used up your region counter and can no longer change the DVD drive's region.
DVD Region+CSS Free works automatically in the background to make a DVD appear region code free and unprotected to any DVD player and DVD copy software. With the help of DVD Region+CSS Free, you can watch any region coded DVD movies with a software DVD player like PowerDVD or WinDVD! With DVD Region+CSS Free's help, DVD copy software (such as DVDFab, DVD X Copy, InterVideo DVD Copy, etc.) is able to copy DVD's which are CSS protected!
New Feature: DVD Region+CSS Free decrypts not just DVD's, it now allows you also to play, copy and rip protected Audio CD's!
Download DVD Region+CSS Free
SECONDLY, You can enter a code on the player that will set it to a certain region. You can find your code at this website: http://www.dvdcodes.net
If it is not on this list, you can also try this site for more codes: http://www.dvd.reviewer.co.uk/info/multiregion/hackable.asp
This site will give you instructions on how to enter the hack code depending on your brand name player: http://www.dvd365.net/?hacks/pacific.htm
2answers
DVD Player region coding changes
You can only change the region code 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play and region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
Hi, We have a Harman Kardon 37 dvd player but each time we put a dvd in we just get message saying 'disc error' any suggestions. We have put in the code to make it region free so this isn't the problem,...
Some DVD's will only work when the DVD player is not region free. Try setting the region code to the correct region. It does not make sense to me either, but don't knock it till you've tried it.
2answers
Need to make laptop notebook packard bell dvd region free locked on o1
You can only change the region code up to 4 times then it locks on the last change.
I suggest you install a region free software that will allow you to play any region DVDs.
4helpful
3answers
Region free code
Hi...put in the DVD then press 1 3 7 9...they will appear as xxxx...then press country code...it will appear as digit, then press " play"
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
