20 Most Recent Sony DVP-SR200P DVD Player Questions & Answers
2answers
In Need of DVD code for Sony DVP-SR200P
Unfortunately the only region code your Sony will play is the one that is printed on the bottom of the unit.
5/8/2020 1:53:18 AM • Sony DVP-SR200P... • Answered on May 08, 2020
2answers
My sony dvp-sr200p, disc tray
Hello
Try the mechanical release;
Look for a very tiny hole in front of the drive; use a paper clip poke through that hole, apply a little pressure and push. The tray should pop open.
there might be a panel that covers the tray, and you won't see the tiny hole. If that's the case, just use your fingernail to pry open the panel, which most likely will pull out (not off), and you'll then see the hole. Once you push the straightened out paper clip into the hole, the tray should come out enough for you to pull it out the rest of the way.
Sometimes the CD drive doesn't open because the case is misaligned. Try pressing on the center portion of the drive when it is attempting to open!
6/17/2019 1:20:03 AM • Sony DVP-SR200P... • Answered on Jun 17, 2019
2answers
Getting a C 13 70 disc is dirty message only for
Hello, welcome to Fixya!Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.If non of the above solves the problem, then know that you need to replace the laser to a brand new one.To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.Once this us done, your player will play all DVD discs again.Good luck.
6/4/2018 9:05:03 AM • Sony DVP-SR200P... • Answered on Jun 04, 2018
How do i to put the dvd on region free code?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock televisions and DVDs"; in the search box at the top left of the display window, to get gathered related posts.
9/12/2016 1:35:13 PM • Sony DVP-SR200P... • Answered on Sep 12, 2016
How to set up remote control so it will work volume and power on my philips tv the sony player i have is a dvp.sr200p
Why not use the Phillips remote to control the DVD instead of the reverse? The Sony codes are listed below. 20533, 21533, 20864, 21033, 21070, 21431, 21536.
4/25/2016 5:01:39 PM • Sony DVP-SR200P... • Answered on Apr 25, 2016
Need to no how to make my Sony DVD player remote work the volume and power on my Philips TV
Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes. 11454, 11054, 10690.
4/25/2016 4:59:03 PM • Sony DVP-SR200P... • Answered on Apr 25, 2016
2answers
My movies are only in black & white
This is a connector/cable problem. Replace the video cable with a new one.
2/11/2016 12:29:55 AM • Sony DVP-SR200P... • Answered on Feb 11, 2016
3answers
I need to unlock the DVP-SR200P to play all
Tell that to my DVP-SR200P ¬_¬
I just bought it, It's regoin 4 and it doesn't play other ones.... I just found out!!!!!
MONIQ
11/18/2015 7:32:37 PM • Sony DVP-SR200P... • Answered on Nov 18, 2015
2answers
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
11/8/2015 12:24:16 AM • Sony DVP-SR200P... • Answered on Nov 08, 2015
My DVD player is saying Playback prohibited by area limitations. What does that mean
You can try the region code hack. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Search the site by keyword "Region code"
7/14/2015 5:22:53 AM • Sony DVP-SR200P... • Answered on Jul 14, 2015
2answers
My dvd player says playback prohibited by area
Sounds like it's the wrong region disc. Try a disc that worked before and if it does than there is nothing wrong with your dvd player it is the disc you are trying to play that has the issue.
7/14/2015 4:55:49 AM • Sony DVP-SR200P... • Answered on Jul 14, 2015
0answers
HELLO
Be the first to answer 8/11/2014 3:20:08 AM • Sony DVP-SR200P... • Posted on Aug 11, 2014Be the first to answer
I would like to know where the tiny hole in the front of the tray is?
I can't help with a picture of the same unit as you have, perhaps you can post a picture of yours with DVD face removed (there isn't such a hole on the intact unit). so that I can inspect it. Your DVD player may not have such a hole. If you consult your user manual I think it tells to you to take the unit to a Sony service centre, but you could the support section of their website. Meantime I attach a picture of computer DVD player, with the hole inside a white ellipse that I have marked in between the LG logo and the button. It's not very visible, being less than 1 mm in diameter (just wider than a paperclip) 6.May.2014 524afd0e-cd1d-47f4-97f7-25c5fe31de77.jpg
5/6/2014 10:46:14 AM • Sony DVP-SR200P... • Answered on May 06, 2014
0answers
Sony DVP-SR200P DVD Player Logo
257 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
movies only in black amp white
  • Televison & Video
