Hi
Call @1-877-778-89-69 Window Tech Support Phone Number
Resolit Microsoft Windows Support
SOURCE: computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
SOURCE: Having Trouble Starting
Enter Safe Mode with Networking.
Update Video drivers.
Restart the system in normal mode and if still no go then you have to reinstall Vista from CD's.
SOURCE: My laptop computer (windows XP, AMD 64 processor)
Applications load at Startup,some may not be required. you can disable Startup applications using MSCONFIG.
Windows XP does not require any program for mandatory Startup.
But you should leave the following to run at Startup.
Also run a cleaning program such as Ccleaner and an antivirus program such as spybot search and destroy to make sure your system is clean and free from viruses.
Please rate this a fixya.
SOURCE: I have a Toshiba LapTop Windows 7 My
Are you using the trackpad to manipulate the cursor, or are you using an external mouse?
If you're using the trackpad, it may be as simple as using the Fn keys and the corresponding F keys at the top of the keyboard to enable the trackpad feature again. If that doesn't work, try plugging in an external mouse via USB port to see if that works.
If you're using an external mouse, then try to see if the cursor moves while using the trackpad.
Hopefully one of these options will give you control back over your cursor again.
SOURCE: Windows 8 is frozen on my Asus laptop - how do I shut down
Hold the power button down until it shuts down.
