VinoTemp VT-TC32G Logo
Louis Knobbe Posted on Aug 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i order of P6R8MC OR0503 relay? - VinoTemp VT-TC32G
Level 3:
  • VinoTemp Master 19,187 Answers
  • Posted on Aug 26, 2016
VinoTemp Master
Level 3:
Answers
19187
Questions
0
Helped
4346261
Points
82261
Http://www.appliancepartspros.com/mcf-ptc-starter-312200500017-ap5671689.html
Testimonial: "Is that a generic replacement?"
  • Louis Knobbe
    Louis Knobbe Aug 26, 2016
  • Brad Brown Aug 27, 2016
    I don't know
Is any P6R8MC start relay a replacement for P6R8MC OR0304?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwje75XzxZSCAxVOmokEHXxQBfsQFnoECBsQAQ&url=https%3A%2F%2Fwww.amazon.com%2Fp6r8mc%2Fs%3Fk%3Dp6r8mc&usg=AOvVaw3s7ZWczicVttYruKA_j6FX&opi=89978449
I have a Haier mini fridge that is not working. I have taken the P6R8MC relay off but don't hear any rattle. Does that mean the compressor is probably bad?
That is what is sounds like but let's check. An overload relay will fail due to wear, a short or a bad compressor will knock it out. There is a rare occasion you may purchased a bad overload relay, but that is rare. The rattling of the overload relay is a good indicator it is bad, however it does not have to rattle to be bad - inspect for burn marks as well.
The clicking sound is the overload relay trying to start the compressor. There will be a pause and then click trying to start the compressor again.
Remove the overload relay component and expose the three pins on the compressor. Using a multi- meter, measure the Ohms across the three pins. You will get one high Ohm reading and two lower Ohm readings. If the two lower readings add up to the higher reading the compressor is good. Make sure the green ground wire is securely grounded. It could nock out the overload. Check for loose connections. Replacing a compressor is a major repair. The cost will exceed the purchase price. Rule of thumb; "If the cost of the repair is 1/3 or more of the purchase price of the unit, Buy new".
As a retired Sears service technician, we considered these units
as throw-a-ways due to the high cost of repair. If you had a service contract we would replace the unit rather than repair it
1helpful
P6r8md
Mr. Ray: Did you get an answer to your question? We may be having the same problem with our Magic Chef wine cooler
Fire Magic 3590A not cooling. Thermostat adjustment has not worked. Compressor warm to the touch.
Exact same thing for me, I replaced the relay switch in the back, part number P6R8MC and it's fixed.
VinoTemp VT60
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20 from AppliancePartsPro
First, unplug the wine cooler and take off the back panel. The back panel is held into place with several philips head screws.
Step 2:
Locate the compressor. You'll find the compressor in the bottom left corner of the VT-60 as viewed from the back. You will see copper tubes coming out of the compressor. These tubes carry the compressed refrigerant to the evaporator assembly. Be careful not to crimp or damage the copper tubing.
Step 3:
Find the black plastic cover to the left of the compressor. This cover is held into place with one philips head screw. Remove the screw and remove the cover to find the PTC start relay.
Step 4:
The relay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
Slide the relay on the connector pins, reattach the blade connector, reattach the black pastic cover over the relay, reattach the back panel onto the VT-60 and you're done.
1helpful
Vinotemp not staying cool, it's set at 54 degrees, but it's at 82 degrees
Step 1:
It's most likely the PTC (Positive Temperature Compensated) start relay that turns the compressor on and off. The manufacturer has replaced part number P6R8MC with part number 6R8MG for this PTC start relay. Order part number 6R8MG, it cost less than $20.
Step 2:
Step 3:
Step 4:
The replay is connected to the compressor by a single blade connector and two pins which protrude from the compressor. Remove the blade connector and pull the PTC relay to the left, sliding it off the pins attached to the compressor.
Step 5:
13helpful
MY FRIDGE STOP WORKING AND THE COMPERSSOR IS VERY HOT. What can be wrong with it it is only 2 years old
Usually when a compresso that is not that old gets hot the problem is with one of 3 components
1. The PTC Relay PN P6R8MC
http://www.repairclinic.com/SSPartDetail.aspx?s=t-P6R8MC-%3d%3di1206838&PartID=1206838
2. Thermal overload PN 265RFBYY
one of many sources: http://www.repairclinic.com/SSPartDetail.aspx?s=t-265RFBYY-%3d%3di1206539&PartID=1206539
3. Loose wiring or terminals
4. Worst case the compressor itself (5 Year carry in warranty!)
Items 1 and 2 above should be changed at the same time. Usually when one fails it causes the 2nd one to fail.
Before you go ordering parts.. just unplug the unit for about 45 minutes. Sometimes if there is a brief power outtage (less than 3 mins) the unit stops and the coolant has not equalized. The compressor keeps trying to start keeping the pressure up but yet the compressor does not start normally. The compressor gets hot and the thermal overload causes the unit to cycle on about every 5 minutes. Over an extended time of cycling the thermal overload will fail. After 45 minutes plug the unit in and see if it starts
If you change the PTC Relay you must change the KliXon thermal overload at the same time. Most LOCAL Appliance part supply stores will have both of these parts in stock. Use the part numbers above and walk in with the parts in hand.
IF you decide to change them your self FIRST make yourself a simple wiring diagram
I.e Orange to terminal ___
Blue to terminal ____
Then remove the parts by opening the plastic cover on the side of the compressor and then pull off the PTC and Thermal overload HORIZONTALLY. Obtain the replacement parts and reintall after inspecting the compressor terminals. Clean as necessary by scraping with a knife blade.
If after changing these two parts the compressor still does not start you may very well have a warranty carry in service compressor change. I seriously doubt that the compressor has failed but it does rarely happen.
This is the Magic Chef support website for parts (linked page) and warranty (top of linked page)
http://www.mcappliance.com/partorder.aspx
Thanks for choosing FixYa.
Kelly
P6r8mc relay burnt up!!!!
reason is that your compressor might overheat or it's overload relay didn't work.
Top VinoTemp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
