20 Most Recent VinoTemp (VT60GNV) Wine Cooler Questions & Answers
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
VinoTemp... | Answered on Aug 16, 2014
try sears parts direct
VinoTemp... | Answered on May 31, 2014
You can fix this for $5. You can confirm the problem by taking the back off and see of the red and green led on the circuit board are flashing. They will be steady if the board is ok. The fan is usually just rocking too like it is trying to start. The part is a capacitor and is $5, but you will need to be able to remove and solder this part on the circuit board. If you need the part, just let me know.
David
VinoTemp... | Answered on May 27, 2014
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
VinoTemp... | Answered on Apr 29, 2014
This problem is typically found in the control board circuit. Probably the 1000MFD 16V Capacitor on the DC side of the PCB may be at fault. The Fix is to replace the capacitor which can be purchased at any Radio Shack for about $2.00. Procedure is to de-solder the the bad component and solder the replacement. This is a polarized component so pay attention the polarity when installing. Test the fix; Properly reinstall the PCB wiring, and Enjoy your Chilled Wine. Recardo.
VinoTemp... | Answered on Apr 26, 2014
I have a different model Vinotemp, but experienced the same exact problem described here where the LEDs on the controller board blinks and there is a clicking or chirping noise. It turns out there was a bad electrolytic capacitor on the controller board that was visibly noticeable (it was bulging). Replacing the capacitor fixed the problem. On my model, it was a 1000 microfarad 16v cap, available at RadioShack or any store that sells electronic components for less than $1. Of course, you will need some soldering skills for this fix.
VinoTemp... | Answered on Jul 23, 2013
VinoTemp (VT60GNV) Wine Cooler Logo
57 questions posted
Top VinoTemp Furniture Experts
Damen Wong
Damen Wong
jasbo
jasbo
John Tripp
John Tripp
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
View Most Popular
VinoTemp Furniture
  • VinoTemp Furniture
Most Popular Question
vinotemp not cooling
  • Furniture
