Monitor doesn't power up, can't hear hard drive run.
Have tried removing covers, blowing out some dust, and reseting connections.
I would start by replacing the power cable to the monitor. If you don't hear your hard drive then maybe the power cable to your power supply is bad or you have a bad power supply. So first make sure the cable that goes from the wall to the power supply is good. If it is good make sure the power supply is turning on. If it is then make sure that the power cable from either the wall or your computer to the monitor is good.
