Samsung 64" Full HD 1080p 600Hz 3D Plasma Smart TV PN64E550D1F Logo
h
hoang huynh Posted on Aug 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung plasma tv pn64e550d1f screen is blank but audio sound good, I was replace main logic control board, y buffer board & y main board but it still same problem, please tell me what can I do?
Power on /off good, screen went blank but audio sound good, I was replace main logic control board, y buffer board & y main board but it still get blank screen. please tell me what can I do?
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Aug 19, 2016
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008299
Points
237762
Contact the authorized service center for Samsung. That is the only thing you can do.
5answers
I have a plasma tv that has two black lines about 50mm wide running vertically in the centre of the screen
Three kinds of detects count for this problem. It could be the Logic board, or the Logic Buffer board, or the PDP panel. Just drop your tv to the warranty depot shop to repair.
Vizio LC470DUG powers on for 4 seconds than goes off--possible mother board
No such thing as a mother board in a TV set. Here is a list of the PCBs
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it may be time to start testing different boards to see if they are functioning properly.
Main Board
The main board, or motherboard, is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. This part is also sometimes called the main module or the A/V (audiovisual) board.
Power Supply Board
Another large and important board inside a television is the power supply board. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long, thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
Timing Control Board / Logic Board
The timing control board, known as the T-CON board, is typically only found on LCD and LED TVs. Plasma TVs, on the other hand, use a logic board. The functions of the logic and T-CON board are similar: each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixilation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
X-Sustain and Y-Sustain Boards
Also known as the X-SUS and the Y-SUS, the x-sustain and Y-sustain boards only appear in plasma screen TVs. The X-sustain board may also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The X-sustain board activates all the display lines at once, while the Y-sustain board addresses all the individual lines of display. When one board breaks down, it probably does not affect the functionality of the other. However, it may be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short lifespan anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
Buffer boards are also only found in plasma screen TVs. Connected to the Y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
Samsung Plasma TV
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts....
TV repair....I have a Samsung plasma. No Picture but it has sound. I'm trying to find out the exact cause of the problem so I can fix it.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Tv repair.for plasma tv
No screen boards found. Do you mean any of these?
Types of TV Boards Every TV uses a collection of various boards to perform every function imaginable in a television. The boards work together to produce sound and images on a television screen. When certain mechanisms in a TV fail, it might be time to start testing different boards to see if they are functioning properly.
Main Board
The main board is the central hub of a television circuit system. The easiest way to identify a main board is to find the board with the various video and audio inputs/outputs. Generally speaking, main boards also contain a tuner, HDMI, USB, and S-video port. Main boards are one of the largest boards in a television. Main boards might also be referred to as a motherboard, main module, or an A/V board.
Power Supply Board
Another large and important board inside a television is the power supply board.. Usually found in the center of the TV, the power supply board has several connectors that supply power to the other circuit boards. It can contain transformers, large capacitors, and integrated circuits. There is usually a table on the power supply board indicating the different voltages it produces in addition to the signal names.
Inverter Board
Found on LCD TVs, inverter boards are used to mount the LCD backlight. These are smaller boards, usually shaped like long thin rods. If an LCD TV's screen is dark, distorted, or difficult to see, it can be the result of a defective inverter board. Inverter boards fail when inadequate power is not allowing current to pass through the backlight bulb.
The timing control board, known as the T - CON board,, is typically only found on LCD and LED TVs. Plasma TVS, on the other hand, use a logic board.. The functions of the logic and T-CON board are similar, as each functions to digitize the information it receives from the TV's processor. This allows the screen to display images on the pixel level. When the T-CON or logic board fails, the screen images may become distorted, leading to pixelation and the appearance of lines on a television. On a logic board, there are slotted connectors on all four sides, while T-CON boards have connectors on just two sides.
Also known as the X-SUS and the Y-SUS, the x-sustain and y-sustain boards only appear in plasma screen TVs. The x - sustain board might also be called the Z-SUS. These boards function similarly, producing proper screen images. Although they serve pretty much the same function, the two boards work independently of each other. The x-sustain board activates all the display lines at once, while the y - sustain boardaddresses all the individual lines of display. When one board breaks down, it probably will not affect the functionality of the other. However, it might be a good idea to have both replaced because X-SUS and Y-SUS boards have a relatively short life span anyway. A failure of one could mean an impending failure of the other.
Buffer Boards
B uffer boards are also only found in plasma screen TVs. Connected to the y-sustain board, a buffer board works to turn output to the plasma display. Common defects of buffer boards include the burning and shorting of power lines.
TV Boards Buying Guide
My magnavox model# 42mf230a/37 tv turns on I get good sound and picture but it has a 4inc black line onleft side edge of screen
Black lines on Plasma TV are cause by either the buffer boards or the logic board. OR your screen is bad. the only way to find out is the replace the boards. I would start with the Buffer boards. The buffer boards are located on the bottom of the screen attached by ribbon cables to the screen. look at the bar and replace the board that lines up with it. You can find parts fro this TV at www.interliquidparts.com You have to get the actual part number from the part on your TV to get the correct one.
My tv lost its color and has a black spot on the screen, can I do to fix it?
Sounds like you YBU-YBL (Y-Buffer Upper-Lower) and the Y-SUS/Main is out. The Y buffer upper controls the top half and the YBL the lower half. The YSUS control all of this. The YSUS is also connected to of course the Power supply board and the logic board.
2answers
LG 42 inch plasma. Half screen is ok (rh side) other side black
Buffer boards or Y-SUS main needs to be replaced. What do you mean by motherboard? The power supply board or the Logic or X main.... They YBU/YBL and the YSUS work in unison. Y-Buffer upper controls top half, Y Buffer lower control bottom have YSUS controls both of those. There is also D, G, E F boards that can split screan. But they to are controlled with the Y-SUS Main. Hope this helps...
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
