Ahmed, Check the attached links,instruction and guides on paring phone to Passat., Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Step by step guide to set up Bluetooth on your Volkswagen
Bluetooth connection problem on passat 3c 2006
http://www.vwaudiforum.co.uk/forum/showthread.php/152377-Struggling-to-pair-device-with-Bluetooth
Pairing Bluetooth to your VW Passat
SOURCE: I can't get my iPhone 3G to detect other bluetooth
The iPhone unfortunately does not pair with just any device, it would be best to check compatibility before purchasing a new peripheral for your iPhone.
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
