Tanaka Hedge Trimmer Tht-2100 Trimmers Clipper Hedger Logo
Max Roberts Posted on Aug 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hedge trimmer Engine starts ok but won't Rev up just bogs down
Bill Boyd
Level 3:
Top Expert:
  • Tanaka Master 53,816 Answers
  • Posted on Aug 10, 2016
Bill Boyd
Tanaka Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951151
Points
172802
Possible problem with dirt or blockage in the main jet of the carby
remove carby and blow out all holes and jets
fit new diaphragm
ensure that the oil / fuel mixture has not excessive oil in the mix
do not use e-mix fuel
Why does husqvarna 123hd60 bogs on revs
Mix up some "carburetor & fuel injector cleaner" in a batch of fuel, Nathan, at the rate specified on the bottle of cleaner. Run it through the hedge trimmer just like normal fuel. For right NOW, you can use the choke to keep the trimmer running. As the cleaner works, you should need less & less choke to keep it going.
It may take a while.
Next time you store that trimmer for winter, drain it fully and run it until it dies from lack of fuel. Then it won't form varnish on the carburetor jets over the winter - that varnish is what's causing your problems now.
2answers
Why does the machine it stall as soon as I rev and it is about to get into gear to move the blades
there should be a clutch associated with this machine, eyeball it and check for a broken clutch spring or possible just worn out clutch, good luck
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Km90 starts but won't run on full revs
The KM90 is a 4mix engine that has valves. You may need to check the valve clearance, using the clearance tool.
Stihl hs45 hard to start when started won't rev and cut's out
Most likely a fueling issue, Check fuel line for air leaks or it could be a carb problem.
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Top Tanaka Garden Experts
john h
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
