SOURCE: WPSF5170W0WW G.E. Profile Performance Washing Machine
most ge washers you just get ya fingers under the bottom and jerk up hard they have a plastic piece under them that has to be replaced from time to time its no big deal
SOURCE: GE WASHING MACHINE GE PROFILE
There is a product out there called Affresh. It is a tablet that can be used on all front loaders that do not have a Clean Cycle. It works great. It comes three tables to a bag. You should use all three the first time that you do this. After that, once a month is all that is needed. Two suggestions to help eliminate the smell and mildew. One, keep a wash rag handy and wipe up any water that remains in the door seal. Second, leave the door open for a day so that the washer can air out. This applies to all front loaders, not just GE, that do not have a Clean Cycle. Also, water sometimes stays in between the inner and outer tub. This water can become stagnant and create mildew, mold, and odor problems. I hope this helps!!! -The Appliance Braniac
SOURCE: GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
please describe the malfunction.
I don't see a question for this post. What's wrong?
