Shortcut win +r is not working
To help you unlock your Windows 10 User account login, there is 'Microsoft Password reset website link' which will get you through your Windows Microsoft User account:
https://account.live.com/password/reset
To guide you step-by-step to unlock the Windows User Account, please follow the link given below:
http://www.howtogeek.com/222262/how-to-reset-your-forgotten-password-in-windows-10/
GuruAid.com
SOURCE: my acer aspire 5720 notebook bios password is not working
Follow the instruction using the link below
http://www.fixya.com/support/r1257563-break_bios_password
SOURCE: user password lockout
Hard disk password is set from the BIOS. It is usually set in conjunction with the Power On Password. This password is stored on the EEPROM chip and is very difficult to crack - no backdoor passwords. It is used to prevent unauthorized access to the laptop and the data on the hard disk. Removing the hard disk and inserting it into another computer will not allow access to data without the HDD password.
SOURCE: How to reset BIOS password on VGN FE880E
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
SOURCE: Dell Precision M65 Locked
I ever used a Windows password recovery tool to bypass Windows password, only with three steps, then left the forgotten Windows password blank. Have a try.
SOURCE: I have 2 problems. 1st problem
Hi Mitch,
To clear the bios password, we need to reset the CMOS battery that supplies power to BIOS (non-volatile memory). You need to open the laptop and do the following suggested in below picture.
Reference Forum Link
If you have only one login account and you have forgotten the password, you have to re-install vista operating system to login again.
Regards,
Riztech
Boot off the Windows disk and select the "Repair your computer" option from the lower left-hand corner.
Follow through until you get to the option to open the Command Prompt, which you'll want to select.
First you'll want to type in the following command to backup the original sticky keys file:
copy c:\windows\system32\sethc.exe c:\
Then you'll copy the command prompt executable (cmd.exe) over top of the sticky keys executable:
copy c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe
Resetting the Password
Once you get to the login screen, hit the Shift key 5 times, and you'll see an administrator mode command prompt.
Now to reset the password-just type the following command, replacing the username and password with the combination you want:
net user geek MyNewPassword
That's all there is to it. Now you can login.
Of course, you'll probably want to put the original sethc.exe file back, which you can do by rebooting into the installation CD, opening the command prompt, and copying the c:\sethc.exe file back to c:\windows\system32\sethc.exe.
