If you mean windows resintall, insert your boot media, turn off the computer, start hitting f9 until you see a list of bootable media, select the one you want and hit enter, then follow the format and install instrcutions,
Unfortunately, the only way to use your phone is to do a hard reset. A hard reset will allow you to reset your password, but you also lose all of your data. Here are two videos on how to perform a hard reset. One video is specifically for your phone (Galaxy S GTI9000): Samsung Galaxy Plus I9001 hard reset
if you perform a hard reset,all user applications and user data will be deleted
please remember to back up any important data before performing a hard reset
1.turn the phone off
2.press and hold volume down + power + lock key at the same time
3.release the keys when the factory hard reset screen appears
4.read the warning and press the power/lock key to confirm.press any other to cancel
5.press the power/lock key to confirm once more or press any other to cancel
6.your device will perform a hard reset
Now, it will be just like brand new phone, except any software OS updates you may have installed during your use.
If you forgot your iphone password you need to do a hard reset. To perform this, you should plug your phone into the computer which you originally set the phone up on. Open itunes. And restore the phone.
Which tablet are you referring to ? You can perform a hard reset to completely wipe out the tablet this will also remove any passwords and configurations. Note: This will also delete all the data currently present. The process for a hard reset differers based on the make/model of the tablet.
Unfortunately, you will need to do a HARD_RESET. A hard reset will erase all records and entries stored in your handheld. Never perform a hard reset unless s soft reset does not correct your problem.
SOFT RESET = USING THE TIP OF YOUR STYLUS LIGHTLY PRESS THE RESET BUTTON INSIDE THE HOLE ON THE BOTTOM OF YOUR HANHELD.
HARD RESET = WHILE HOLDING THE "TODAY" AND "MESSAGING" BUTTONS (a) USING THE TIP OF YOUR STYLUS LIGHTLY PRESS THE RESET BUTTON INSIDE THE HOLE ON THE BOTTOM OF YOUR HANDHELD.
You will have to perform a hard reset. You will loose all data from the iPAQ, and it will be restored to factory conditions.
Hopefully, you've got a backup on a PC or a storage card that you can restore your data from.
