Health & Beauty Logo
H
Harold Swanson Posted on Jul 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The off and on switch won't turn off on mk5 spj. it turns on fine but have to unplug cord to turn off.
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Jul 05, 2016
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129830
Points
552
Harold, you need a new on off switch. You can open the case and solder in a replacement switch after finding a replacement. This is your least expensive option. You can also send it to be rebuilt at Monster Scooter Parts or to the Wheelchair Wizard in Sacramento. Hope this helps. Scott
gmiller442
Level 1:
  • Contributor 17 Answers
  • Posted on May 04, 2019
gmiller442
Contributor
Level 1:
Answers
17
Questions
0
Helped
12480
Points
56
I have an Invacare Pronto M91 with the SPJ+ controller and it was doing the exact thing you describe. Easy to turn on, but very difficult or impossible to turn off. I replaced the keypad on the controller and now it works like a champ. Easy on-Easy off!! I believe the key bad buttons have graphite on them and then it wears off with time, causing the above issue. They can be ordered for about $32 from Monsterscooterparts.com
Elite 7700 treadmill. Why is there no power to console?
If the electrical outlets work and are fine unplug the treadmill and then check the power cord for any damage. Replace the power cord if it's damaged. If the power cord is fine and looks fine then check the circuit breaker switch on the treadmill and reset the circuit breaker switch if it's tripped.
Invacare M51, joystick mk5 spj. Broken momentary switch. Have removed screws but can't open joystick to replace switch.
buy tadalista CT 20 online contain of Tadalafil . buy tadalaista ct online from your most reliable Trusted online pharmacy Medypharma. Cheap tadalista ct 20mg in USA. Tadalista online india. Know about tadalista ct uses , Price , How to take , Side Effect , How to use . tadalista ct online , tadalafil chewable tablet. Tadalista CT 20mg
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Pixma ip1600 won't turn on. No power cord just a cord from printer to computer. I unpluged the entire system and waited 15 minutes and it still won't power up. Any suggestions?
You need the power cord which has a polarized plug on one end. The other end (a figure 8 like shape) will fit into the printer. See http://gdlp01.c-wss.com/gds/7/0900005347/01/ip1600esi_us.pdf . Amazon and other sites have replacement power cords for Canon inkjets and inkjet multifunction printers. One source: http://www.amazon.com/Canon-ip1600-ip6600d-ip6700d-Printer/dp/B003XT2LKC .
I hope this helps.
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
1helpful
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
1helpful
3answers
Our FisherPrice SMart Cycle won;t turn on...help!
I would suggest unplugging the 3 RCA connection cords and making sure they are all tight. I had the same problem when I first hooked the system up. After unplugging and reconnecting the RCA cords it worked fine. I do have a problem with the system resetting periodically... will check the power switch to ensure the screws are tight.
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
