SOURCE: Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
SOURCE: I have the samsung rs2577sl. the ice maker cube
Your model has the twist tray style icemaker. The part number for you front section that contains the motor assembly is DA97-00258E Ice Maker Assembly. You can try by taking it out and seeing if the tray will return to the home position but stopping there make me question if the thermal fuse in wiring harness may have blown. We may need to test that wire also to see if the thermal fuse is still good, I will leave you some of the links and ready to help when you need me, Thanks, Sea Breeze
SOURCE: My Samsung refrigerator ice maker
I have the same problem. I just called custormer support and they are shipping me a new ice bucket to resolve the issue (I'm still under warranty). Based on the agent's quick response, it seems that this is not an uncommon problem.
